Page 1 of 2 12 LastLast
Results 1 to 20 of 25
    Nov 2013
    Just had a rear bumper repainted. Off parin ang shade after 3 attempts ng casa. Sabi saken they used the correct paint code naman, now I'm still unhappy about the results and wondering why can't they get the color matched perfectly. I do understand that bumpers are a little bit darker than the body, but mine is way darker than the rest of the car at certain angles.
    How do I instruct the casa to get the metallic density correct?
    Aug 2012
    how old is the car? just following the paint code will not always guarantee exact match. you need a good painter that knows how to mix and/or blend colors.
    Nov 2013
    Quote Originally Posted by red_one View Post
    Sir 9 months na yung car.
    I told them to adjust the mix to a lighter shade. Naka tatlong balik na yung auto mali parin.
    Acceptable na ba yan?
    Posted via Tsikot Mobile App
    Oct 2013
    Ang alam ko, aside from paint code, they are also weighing the paints for proper mixture, and also they are matching it for the faded color also, hindi pa ganun kagaling sir mga pintor sa casa na napuntahan mo.
    Nov 2013
    Quote Originally Posted by vvti2.0 View Post
    Kaya nga eh. Yung 3rd attempt sabi nila ni-compare muna sa katabing panel bago bugahan, ganyan parin result.
    So ipabalik ko na lang?
    Oct 2013
    Yup, mali yung halo nila.
    1. paint surfaces that have been exposed to the elements, do shift a little with time, such that the computer's memorized formula for that paint code, might not be a perfect match anymore.
    2. the underlying surface might contribute a little to the final shade.
    3. all humans differ from each other a little, when it comes to color and shade perception.
    Aug 2012
    Quote Originally Posted by Yuki13 View Post
    if i will based on the photo, not acceptable. obvious ang difference ng shade.
    Nov 2013
    Right. They should adjust the paint mixture based on the current condition of the car. Factory paint code won't work for my car.
    Nov 2013
    Alright. Will have this repainted.
    have you noticed, the most common complaint regarding paint shade mismatch, involves the plastic bumper versus the rest of the (metal) panels..?
    Nov 2013
    Yep. Even factory paint plastic bumpers are a bit darker than the metal panels. Barely noticeable though.
    To undiscerning eyes, there is nothing wrong with the paint
    Aug 2012
    i think konti lang effect ng material. if you think about it, both will be coated with several layers of primer, base coat and clear coat. kaya pwede talagang ma-color match. nasa pintor na lang talaga ang diskarte dyan.
    metal + layers of primer, base coat, clear coat
    plastic + layers of primer, base coat, clear coat
    Aug 2012
    pwede rin, nasa tolerance level ng owner if acceptable na ung color or not. ibang usapan na lang kung talagang off ang colors.
    Nov 2013
    Yes. You really have to try to see the difference.
    Nov 2013
    In my case, the difference in the shade really "pops". So I'm really keen on having this corrected.
    Nov 2013
    I've asked around din naman, some say that obvious nga ang difference, some say I'm being over OC. It's not that bad nga naman if majority of those who look at it won't see.
    Also dropped by big bert's & other detailers sa area ko to get their thoughts on the paint job, ayun nga daw paulit ko na lang.
    Jan 2010
    kaya po nagbabago ang kulay kasi po meron static yung plastic bumper,. nabubulabog po yung pintura lalo na po yung metallic colors gumagalaw po yung metallic kaya nagiiba yung kulay, subukan po nyo ilapit yung braso nyo sa bumper at mararamdaman nyo yung parang gumagalaw yung buhok sa braso, ang dapat gawin ng pintor kapag nakuha na nya yung desired coverage [ opacity ] kailanggan po sya mag 2 mist / drop coat, kailang po edouble yung gun distance para umibabaw yung metallic para di mag dark yung kulay
    Nov 2013
    ^sir i'll ask them to try adjusting the gun distance next try. ano yung 2 mist / drop coat? I want to give specific instructions na para umayos.
Off shade Paint Job
