Results 21 to 30 of 31
- Jan 2008
- 154
March 5th, 2008 06:13 PM #21gas shocks sa rear para nakataas likod mo
fluid shocks sa harap para di matagtag
wag ka maglagay ng gas shocks sa front baka tingala auto mo pagnagkataon
or kung gusto mo maghanap ka ng coilover set alam ko 16k+ meron na H&R
March 5th, 2008 06:21 PM #22
March 5th, 2008 06:29 PM #23
March 5th, 2008 06:33 PM #24
March 5th, 2008 06:36 PM #25
Ask these guys on what they have for the Civic:
www.speedlab.com.ph
www.speedyfixph.com
March 6th, 2008 02:15 AM #26
kulang budget mo pards for 50K kailangan mong mag prioritize
1. good washover cost 20K++ meron din 18K canvas ka nalang
2. seatcover - dapat may sidings din 1,4K sidings 5K cover
3. mags 16K brandnew rotas depende pa sa design, sa evang mga 15K o 14K pero di ka sure kung recondition o brandnew
4. bridgestone nasa estimate 4K ++ isa niyan x4 pa yokohama, dunlop mas mahal ata
5. shocks kung apat magkaiba presyo sa harap at likod
set ng gas sa harap nasa 2,5 each x2 5K (estimate)
set sa likod 1,5K each x2 3K gas na yan (estimate)
6. lowering spring, iwas lang sa taiwan made matagtag daw pero cheap pinakamura kong alam na spring na maganda e yung "sprint" 6,5K brandnew kaso 1.75 drop nun
di pa kasama sa budget mo yung pakabit ng shocks + spring raging 350-500 isang side niyan bale x4 pa yan
kulang kulang 80K ka niyan cguro pag 100K ang budget mo meron ka na niyang sound setup hehe
goodluck sir sa project
March 6th, 2008 12:16 PM #27
March 6th, 2008 12:24 PM #28
Definitely unahin mo muna ang mga urgent concerns such as engine/tranny supports, bushings, shocks, timing belt, fan belts. Once na in good running condition, then that's the time na aesthetics naman.
March 6th, 2008 12:40 PM #29
Ok. Just as long as you know what's in good condition and what's not. You can skip the brakes if they're okay.
I'd get that roof repaired... it's common... di naman life-threatening, but the rust can spread.
Shocks and springs, sorry, I don't know what's good for your car, you'll have to ask around at Honda Club Philippines: http://www.hondaclub.com.ph/v4/home.php
For opinions on the best set. Try to search the net and club sites for a set of lowering springs that have low spring rates. Softer, "cosmetic" lowering springs will not destroy stock shocks as easily as "performance" lowering springs. This way, you won't have to spend extra on shocks.
- Mar 2005
- 97
March 6th, 2008 12:44 PM #30If it was up to me
1.Engine - Pa kondisyon mo with yopur trusted mechanic. Change plugs, check valve clearance, oil leaks etc.
2.Battery - If this needs to be replaced
3.Underchassis - On a buget Cruven or Zee
4.Tires - Kung makapal pa naman kahit hindi muna
5.A/C - Cleaning/Service (Malapit na summer)
Pag nagawa na yan saka ka na pa pintura
Seat cover - mura lang naman yan a friend got seat covers for his esi from ace hardware for 700pesos (pero sale nun) - simple lang black na tela pero elegante and hindi dumihin
Xiaomi E-Car
