i haz bug&tar remover for this kind of job..
or try this..
RUBBER & BUG REMOVAL TRICK: How to do it Safely! - YouTube
or try this..
i suggest you need to bring back your car to your coating shop. they may have a fix or remedy to remove the tree saps without harming their own ceramic coat. but it might be for an additional fee na yan. tree sap is one of the most difficult contaminants na tanggalin kapag dumikit at na-dry na, so as with ashpalt and bird poop...
I have a sealant and I have no issues with bird droppings, tar and bugs. These things shouldn't affect the coat if it cured properly. maintenance washes and of course tar/sap/bug removal if necessary...
coat maintenance wash..
basically a car wash for your coat...
if heavily soiled... you still need a waah to soften the dirt..
either way coat needs maintenance...
Best Techniques For Washing Your Car: ATA 104 - YouTube
I bought some products at Amazon to maintain the glass coat of our car. Carpro has their Reload spray. Gyeon has their Cure spray. I went with Gyeon to try it out.
Rinse then foam wash using ph neutral shampoo then use the maintenance spray as a drying aid.
**Also bought Gyeon Wet Coat to try out to our non-coated cars also**
What product sir? And where did you get your glass coating?
Carpro products are also sold by the same seller from paranaque where I got the ONR. There's the reload and the ech2o. The ech2o is like ONR, where there's a ratio for QD, no rinse and clay lube.
Sent from my MI NOTE LTE using Tsikot Forums mobile app
Top 5 Tips to Maintain a Fresh Detail: ATA 107 - YouTube
his black Porsche is amazing. tires and custom wheels too 😀
*kinto92
Ung glass coating ko sa tabi tabi lang haha sa shop ng friend ko. I think pika2rain gamit nya, from japan.
Product na binili ko sa amazon is Gyeon Cure and Gyeon wetcoat. Gyeon cure is their maintenance spray. Mga once a month to maintain glosiness and hydrophobicity. Should work with other brand's coating as well.
Gyeon wetcoat naman is for our cars without any coating. Will try it out kung it works as advertised.
First time I washed the car with coating the other day. Sobrang bilis nga linisin. The water just drops off unless puro flat surfaces. Buhos mode na ako. Hehe.
*montro,
Not sure kung may local reseller. I dont think Gyeon is Lithuanian though.
^ found a local distributor/detailer of Gyeon here in the Philippines. Its in the south though, along daang hari road.
