Page 1 of 2 12 LastLast
Results 1 to 20 of 34
    Sep 2011
    topic
    kanina habang nag lilinis ako . may napansin ako sa rear bumer ng sasakyan. na ayaw maalis..
    ma iitim na tuldok tuldok..
    tapos napansin ko na rin left and right side merun rin kaya nag hinala ako baka espalto...
    di ko talaga maalis. peru kapag kinutkot mo ng todo natatangal siya. peru baka masira naman kasi yung pintura niya
    na experience niyu na oi ba to? . anu ba mga sir ang mabisang pang alis .sa ganyan :sweat:
    picture's :
    Jan 2009
    If you have WD40 on-hand, just spray a coating on the affected areas and leave it on for about a minute. It will easily dissolve the asphalt/road tar. Wipe it off using a clean cloth and re-spray on the stubborn ones.
    Shampoo the car afterwards to remove the oily residue.
    Spray kerosene, leave for 1-2mins or until asphalt softens, wipe with MF cloth, wash with car shampoo. Hehe.
    mukhang aspalto nga yan sir... pangit nga yan lalo na white pa yung kulay ng auto mo... yung sa starex namin dati meron din, di ko na lang pinaalis kasi dark naman yung kulay so hindi halata...
    Hindi ba nakaka sira ng paint finish yung kerosene sir? I've seen carwash boys use a solvent na pang tanggal ng asphalt but im not sure kung kerosene yun. Ma tanong nga sa sunod na washing..
    i've attended a seminar with a famous brand of automotive cleaning products... its main office is in kamias ...and they use kerosene to remove asphalt. i guess its safe as long as you wash it afterwards and apply protection such as wax
    Sep 2011
    Hindi naman po kaya sir. Masira o mairita ang paint sa wd40
    medyu nakakaba eh
    Sep 2011
    *junerski
    Try ko sir kerosine . Ito rin naiisip ko
    Kasi naalala ko nun may naka sabay ako na taga la union sa 9year old na revo niya sabi sakin kerosine daw sekreto niya kaya makinis parin paint ng auto niya. pinupunas daw niya sa buong katawan every 1 month
    Safe ang kerosene,- basta iwa-wipe off mo lang totally.....
    Bro.ecneret...,- iyan ang kagandahan ng side cladding,- walang masyadong concern sa talsik na aspalto...
    16.2K:bat:
    May 2011
    tried to check at youtube.... meron nga (i use kerosene or turtle bug & tar remover eh)
    Apr 2012
    karosene ang pangtanggal ng espalto......
    Aug 2010
    Kerosene and solvents would work. But most cost-efficient is kerosene definitely.
    Huwag mo lang sindihan
    Sent from my iPad using Tapatalk HD
    Damo ang sinisindihan bro,- hindi ang solvent... :hysterical:
    16.2K:bat:
    Jan 2004
    16.2K:bat:
    solvent sinisinghot
    pag sinindihan hindi ka na magkakaproblem uli sa aspalto.
    I usually have the car wash/detailing shop do the "asphalt removal" (they normally use kerosene) then i wax it when i get home.
    Don't use gasoline (masyadong matapang).
    Jan 2003
    The safest would be using a clay bar. Then apply wax after. This will remove other contaminants from the paint as well.
    Jan 2008
    sa car wash ang ginagawa nila, water wash muna yung sasakyan para maalis alikabok, tapos using a sprayer, spray nila yung kerosene then pahid sa sasakyan para matanggal asphalt at iba pang dumi... tapos wash ulit, then dry tapos wax
    Aug 2010
    Quote Originally Posted by non-vtec View Post
    Actually, safest would be first softening the asphalt first before immediately claying. Immediate claying would only harm the paint as asphalt sediments are pretty tough to remove and would scratch the paint if you attempt to do so.
How to remove espalto.
