Results 11 to 19 of 19
January 13th, 2003 07:18 PM #11
hose from the radiator? or do you mean hose from the radiator reservoir? usually that hose will not drip water unless you've overfilled your radiator. This commonly occurs when you fill up your radiator through the radiator cap instead of the reservoir. It also occurs when you fill up your reservoir over the "FILL" line.
- Nov 2002
- 34
January 14th, 2003 09:04 AM #12Originally Posted by theveed
Anyway, how can I remove those stains?
January 14th, 2003 09:28 AM #13
I just would like to share my experience. Nagpalinis ako ng engine bay dyan sa Petron Buendia. I guess the one who did it got careless because when i started my car, the hi-tension wire got busted.
:xTapos ayaw nilang bayaran at sa akin pa pinapapalitan!:evil:Imagine 5Thou ang original, buti naman at nakakita ako sa Evangelista for 350 pesos only. Naawa lang ako dun sa tao kaya di ko na hinabol. Never na ko magpa-service dyan sa Petron na yan. Bad trip!
- Nov 2002
- 34
January 14th, 2003 12:07 PM #15Anyway, how can I remove those rust stains?
January 14th, 2003 12:11 PM #16
Erick: It'll be easier to "picture" if you can upload a pic of the problem... I can't figure it out eh... but have you tried WD40? It works great for most rust stains...
- Nov 2002
- 34
January 14th, 2003 02:58 PM #17Originally Posted by theveed
January 14th, 2003 03:40 PM #18
Naputol, parang sunog. I suppose when it got wet, a partial ground occured.
I personally really like the XV But I think its too expensive. So I'll vote for the brand new...
2020 Subaru XV vs 2022 Honda HRV 1.5T
