Results 31 to 40 of 43
- Sep 2008
- 7
April 7th, 2014 03:54 AM #32The problem you guys experienced is called acid etching. water spot is caused by minerals left after the rain evaporated or water is left to dry, they are mainly salt, which is alkali. LOW COST water spot remover uses acid to neutralize the alkali, these acid remover are quite difficult to handle, and may cause acid etching. if not neutralize, the etching may permanently damage the glass.
- Feb 2005
- 342
April 14th, 2014 02:57 AM #33Just got a pack of Rain Clear Gel with Rain Scrub glass cleaner... let see if its good. Meron rin akong nakitang yung cleaner and repellant all in one spray... forgot the exact name pero from glass science din. got the aforementioned pack na lang kasi mas tatagal.
- Feb 2005
- 342
April 21st, 2014 09:36 PM #34Tried the Rain Clear Gel and it works well. It is pretty tough to remove or I dint do it quite right, but after getting a car wash the excess film got removed and it repels the water as advertised. I would not recommend this on newer cars though since they already seem to have repellent already or are just unmarred.
Be prepared with a lot of elbow grease when applying and "buffing" it off.
July 25th, 2014 06:59 PM #35
- May 2011
- 227
December 10th, 2015 12:05 PM #37Wala na un rain clear gel sa blade di ko natry sayang haha binili ko na lang un rain repellant ng blade 88php nakalimutan ko may rain x pala ako sa bahay sayang haha
- Jan 2016
- 3
July 20th, 2016 11:28 PM #39
July 21st, 2016 02:01 PM #40
important note with acid based watermark removers is not to let the chemical dry on glass. else mag "foggy" sya. dapat small sections at a time lang. i work on an area no bigger than 1ft x 1 ft then rinse with soap and water. proceed to next section.
You would need a glass polish to remove them. i have remove these type of glass defects including wiper scratches with carpro ceriglass at rayon
Xiaomi E-Car
