Results 1 to 9 of 9
December 10th, 2003 05:21 PM #1
http://www.youcansave.com/dent.asp
What do you think of this PDR tool? Pwede na kaya as DIY tool for minor dent?
BANNED BANNED BANNED
- 3,790
December 10th, 2003 08:23 PM #2looks ok...pero I believe it work only on limited occasions or cases of dent
December 10th, 2003 09:29 PM #3
Parang ganyan din yung gamit nila theveed. Not advisable for repainted vehicles.
December 10th, 2003 10:09 PM #4
I think the guys at Car & Driver tried out if an amateur can really do PDR using the said device.
They were not very successful at it. Skill is still a very vital ingredient.
- Jan 1970
- 114
December 11th, 2003 10:13 AM #5DIY dent removers like this works only on some dents...on some, hindi niya kaya. Especially if the dent is near a ridge. If it's like a dimple on a flat surface, kaya niya. The key to dent removers like this is the glue. It has to be strong enough to stick to the surface while you're trying to pull the dent back, while remaining brittle enough to break off without taking the paint with it if you fail to pull the dent out.
- Jan 1970
- 114
December 11th, 2003 10:14 AM #6Oh, here's a review of the ding king. Can't vouch though for the site that made the review:
http://www.tvgadgetjudge.com/ding%20king%20review.htm
December 11th, 2003 10:42 AM #7
It seems DING KING is ok for minor dent up to the size of 1 peso coin. Ok sanang project for DIY guy like me he he h.
Problem is wala pa ata sa Pinas ito. Cannot be ordered via net kc for Canada, US and Uk pa lang pwede. Ung may relatives cguro abroad can get it. Thanks
December 11th, 2003 10:54 AM #8
nasubukan ko na yan, pero it doesnt work kung mas maliit pa sa diameter ng Ding King ang dent. Saka kapag nasa corner ng body ang dent, hindi uubra.
December 12th, 2003 12:28 AM #9
medyo 50/50 yan... it works on some dents, it doesn't for some... with my corolla before it got rid of a couple of light dings but some didn't come off even if it's very light... Dont know why, it's a bit finicky to determine how much adhesive to use and how long it should stay...
like what ungas said, all pdr methods are only recommended for factory finishes and will not work with repainted cars since repainted panels will never adhere as well as factory finishes.
Before the power run both filters are already primed so pre-fill should no longer be an issue, but...
Thick (20W-50) vs Thin (5W-20) Engine Oil Tested
