Page 80 of 83 FirstFirst ... 30707677787980818283 LastLast
Results 1,581 to 1,600 of 1650
    Apr 2008
    #1581
    gurus...
    after washing madami akong nakitang acid rain sa hood and trunk.. ang ginawa ko eh ni-rub ko ng vinegar tapos may nakita parin ako kaya ni-clay ko siya...
    ok lang ba gamitan ng vinegar? may nabasa ako somewhere using a vinegar to remove acid rain.. i don't know lang kung para sa salamin lang yun...
    #1582
    Quote Originally Posted by jmpet626 View Post
    Lahat yan pwedeng kabitan ng Velcro Buffing pads. Mas maraming ang rerecommend ng Portercable for newbies. Yung portercable hiwalay pa yung backing plate niya while yung Griots at Megs meron ng kasmang backing plate.
    tnx jmpet!
    Quote Originally Posted by madkatz View Post
    if you ask me the last choice among the 3 would be the Megs G110 V2, i've seen and heard lots of bad reviews about it being like a Pc 7424 the old version
    i would recommend Griots and PC, i would recommend Griots if you are planning on correcting the car frequently and the PC if you value your eardrums basically the main different would be
    Griots uses a D handle which is more comfortable for long term polishing
    PC vibrates and produces less noise which is a relief for the eardrums
    so i guess it would be a matter of preference
    Also the Griots has about 10% more power over the PC 7424xp as some people say but it comes at the price of vibrating and being a lot noisier than the PC 7424XP
    tnx madkatz!
    May 2010
    #1583
    i am just starting to buy some wax and things needed to maintain my car, para narin tipid and somehow kampante ka kasi ikaw yung nalilinis ng sasakyan... may i just ask if this are ok kasi medyo natitipid din po;
    the dub brand being sold at blade mura kasi shampoo and its carnuba wax ok lang ba ito na brand to try?
    my friend told me did and he is using it on his car yung paralux glaze, and indeed makintab yung car nya, may masama po bang effect ito or ok lang syang gamiin and how ofen pwede gamitin?
    Tia
    Jun 2010
    #1584
    *madkatz
    Hi maam, is it okay if I layer NXT 2.0 over moms step 2? Will the two bond properly? Thanks
    Jun 2010
    #1585
    *madkatz
    Also, are carlack68 NSC and LLS stand alone products? Or should LLS always be layered over NSC? Thanks maam.
    Aug 2009
    #1586
    Quote Originally Posted by Hardinero View Post
    gurus...
    Vinegar should be pretty harmless to the paint if not left to dry, but once you leave it to dry it has a very big chance of etching the paint, remember vinegar is acid and acid rain actually has a less acidic PH level and can already etch the paint and cause watermarks what more a stronger acid like vinegar? Vinegar is generally used on glasses and at times on paint but the reason why these are used to treat water marks is dependent on what water marks you are dealing with, if the water marks are caused by mineral deposits then using vinegar can help soften and dissolve some of the mineral deposits making it easier to remove, but with using vinegar you should never let it dry on the paint, once it dries on the paint thats quite a recipe for disaster, some people claim using natural vinegar is quite harmless but my say is, why even risk it? Next if the water marks are caused by acid rain etching then using vinegar is actually gonna make matters worse since the current condition of the paint is weak against acids. So if you ask me i really wouldn't recommend using vinegar except on glass
    if you problem is mineral deposits, try to do a quick clay and check if that does the trick
    if its still there then use step 1 to remove the etching, if its still there you might need to polish the paint already
    Aug 2009
    #1587
    Quote Originally Posted by dreamer21 View Post
    Tia
    Hello, using some form or car maintenance product is better than using none at all, so to answer your question yes its better to use Micro Magic/Dub brand at blade than not use anything at all, and when it comes to wax, something to protect the paint is better than nothing, but of course there are tons of other stuffs out there that are better than these items, if you could squeeze in a little more budget try the Microtex Shampoo 150 only and try the Nano Glos its at 360 only for the 500ml, if you have more budget try the mothers line
    i am familiar with the Paralux brand but not with the glaze, paralux is known for paints but not too much in relation to automotive paint, next the glaze in its industry essence is really a gloss enhancer but doesn't offer protection, so if you ask me if the Paralux Glaze can improve the gloss im quite sure it can improve the gloss but im also leaning towards the idea that it doesn't protect the paint, glazes are glazes and in its basic essence a glossing agent, some glazes contain protective elements but its not really their main forte, a good suggestion would be to use that same Glaze and apply a carnauba wax on top to seal the glaze, this would give you that great shine and also give you protection
    Aug 2009
    #1588
    Quote Originally Posted by kafph2000 View Post
    *madkatz
    Yes its perfectly ok to put NXT on top of Step 2, no waiting time BTW
    Aug 2009
    #1589
    *madkatz
    NSC and LLS are a lot more durable when used in conjunction with each other, both can be used as a stand alone product, you can use NSC and get decent protection and with LLS you just have to make sure the paint is clean and free from oils and other elements that might interfere with the bonding process, But i would strongly recommend using then with each other since they are really developed to be used together, its like if you use them individually you only get at most 50% durability but if used together you get 100% durability, something in that train of thought, basically the improvements in the results are very very far when used together compared to used individually this aspect covers mainly durability
    May 2010
    #1590
    thanks madkatz and very much well explain and for the suggestions
    actually i have a microtex shampoo and formula, 1 carnuba wax and zymoil quick detailer and just recently tried the 3m paint protect, i really like to buy the mothers 1-3 step products in the future if buget permit lalu na yung clay bar.... i also have tons sets of micro fiber cloth (yung mura nga lang at generic lang) for drying and buffing well i am applying .....
    agin if bugget and time permits i will convert my Kinzo rotary sander into a polisher which i bought i think 5 years ago in Makro since it has variable speed... i just need diy adaptor to attach a boch polishing kit.
    Aug 2009
    #1591
    Ohh, then better stick with those, Microtex shampoo is a lot more gentle so you're sure not to strip waxes, Formula 1 Carnauba Wax is actually a decent OTC wax, its durability stand up there with the longer lasting ones but its downside is that its very hard to remove, Zymol QD is also great, cheap and good value cleaner QD
    As with the rotary sander, that sounds like a plan! looking forward to your successful update with it
    Jun 2010
    #1592
    Thank you very much miss madkatz!
    May 2010
    #1593
    Ill give an update and some photo too if and when i have able to finish it,
    just a fllow up question po, when i apply some wax i find it very convenient to spray water on the applicator/cloth before or everytime i put a wax on it then apply it to the surface or sometime even to on surface of the car i do spray water on then apply the wax and even on QD and napapansin ko by doing such parang mas even yung paaaply and parang mas matipid hehehehehehe any insite on this maam/sir?!? madkatz... diko po kari alam kung maam or sir eh hehehehehe
    Apr 2008
    #1594
    many thanks madam...i'll never use vinegar na lang to be on the safe side..
    ano ba medyo mura murang QD na may shine and protection na rin as bonus..though mas priority ko yung shine...
    medyo malakas kasi ako sa QD since black tiskot after ko kasi i-dust with cali duster there are times na sinusundan ko ng QD....
    before i'm mixing wax as you dry dilluted with distilled water 1:1 ratio (dunno if this is good )..
    or kahit cleaning QD lang...badtrip kasi minsan yung nagca-carwash sa mall natatalsikan ka sa gilid saka yung nagbubukas ng trunk na mga guards...yung fingerprint sa trunk....grrrrr....
    kaya malamang tatawagan ko yan admin ng moa...as paying customer eh siguro naman may right tayo mag-demand..
    Mar 2005
    #1595
    Kung Cleaning QD ang pinaka economical Optimum No Rinse or DP Rinseless Wash and Gloss. 32oz can make 4 gallons of QD.
    Aug 2009
    #1596
    Good day po!
    Aside sa Wax coating, meron pa bang pwedeng ilagay after mo gamitan ng wax yung paint ng car mo? (For double protection.) Any suggestion sa Brand or product po?
    Aug 2009
    #1597
    using water with waxing by spritzing some mist on the pad is a common practice actually but i haven't tried it with a QD
    its maam BTW
    Aug 2009
    #1598
    Microtex Nano Glos, Megs Last Touch, FK 425, ONR and OID are all very economical QD's that deliver great results
    Aug 2009
    #1599
    Quote Originally Posted by red16 View Post
    Good day po!
    i believe that you would be looking for a sealant, its different from a wax but it compliments a wax by improving the durability, try klasse/carlack brand twins, these are basically some of the benchmarks for sealants
    Jan 2010
    #1600
    Guys,
    Ano bang recommended speed when using ROP when apply polish, wax, sealant, etc. and also when buffing? Thanks.
Detailing Thread [For Newbies][continued]
