Quote Originally Posted by madkatz View Post
Vinegar should be pretty harmless to the paint if not left to dry, but once you leave it to dry it has a very big chance of etching the paint, remember vinegar is acid and acid rain actually has a less acidic PH level and can already etch the paint and cause watermarks what more a stronger acid like vinegar? Vinegar is generally used on glasses and at times on paint but the reason why these are used to treat water marks is dependent on what water marks you are dealing with, if the water marks are caused by mineral deposits then using vinegar can help soften and dissolve some of the mineral deposits making it easier to remove, but with using vinegar you should never let it dry on the paint, once it dries on the paint thats quite a recipe for disaster, some people claim using natural vinegar is quite harmless but my say is, why even risk it? Next if the water marks are caused by acid rain etching then using vinegar is actually gonna make matters worse since the current condition of the paint is weak against acids. So if you ask me i really wouldn't recommend using vinegar except on glass
if you problem is mineral deposits, try to do a quick clay and check if that does the trick
if its still there then use step 1 to remove the etching, if its still there you might need to polish the paint already
many thanks madam...i'll never use vinegar na lang to be on the safe side..
ano ba medyo mura murang QD na may shine and protection na rin as bonus..though mas priority ko yung shine...
medyo malakas kasi ako sa QD since black tiskot after ko kasi i-dust with cali duster there are times na sinusundan ko ng QD....
before i'm mixing wax as you dry dilluted with distilled water 1:1 ratio (dunno if this is good )..
or kahit cleaning QD lang...badtrip kasi minsan yung nagca-carwash sa mall natatalsikan ka sa gilid saka yung nagbubukas ng trunk na mga guards...yung fingerprint sa trunk....grrrrr....
kaya malamang tatawagan ko yan admin ng moa...as paying customer eh siguro naman may right tayo mag-demand..
