Originally Posted by
madkatz
Vinegar should be pretty harmless to the paint if not left to dry, but once you leave it to dry it has a very big chance of etching the paint, remember vinegar is acid and acid rain actually has a less acidic PH level and can already etch the paint and cause watermarks what more a stronger acid like vinegar? Vinegar is generally used on glasses and at times on paint but the reason why these are used to treat water marks is dependent on what water marks you are dealing with, if the water marks are caused by mineral deposits then using vinegar can help soften and dissolve some of the mineral deposits making it easier to remove, but with using vinegar you should never let it dry on the paint, once it dries on the paint thats quite a recipe for disaster, some people claim using natural vinegar is quite harmless but my say is, why even risk it? Next if the water marks are caused by acid rain etching then using vinegar is actually gonna make matters worse since the current condition of the paint is weak against acids. So if you ask me i really wouldn't recommend using vinegar except on glass
if you problem is mineral deposits, try to do a quick clay and check if that does the trick
if its still there then use step 1 to remove the etching, if its still there you might need to polish the paint already
