Page 42 of 83 FirstFirst ... 3238394041424344454652 ... LastLast
Results 821 to 840 of 1650
    Feb 2010
    #821
    Quote Originally Posted by scharnhorst View Post
    *ma'am madkatz: thanks for answering the query ma'am...
    nagdeteriorate ata agad yung sealant at yung fleetwax against fulltime outdoor parking with rain
    Sir, mas matagal talaga pag pinapatungan ng booster yung 476, lalo na pag winawash
    Yes doc, if the car is put into harsh environment....wax is depletes faster than normal.... try mo 2-3 times a week mag wash...tatagal pa rin 2 weeks 476....under harsh condition (ARAW/ULAN).... kahit di ka mag booster...syempre mastatagal ng onte yung me booster...
    Jul 2010
    #822
    Quote Originally Posted by PSI View Post
    sirs tanong lang.. if pinatungan ng ibang wax as booster yung 476 or fleet.. same padin ba yung effect ng beading na binibigay ng fleet or 476? kasi yung pinataong na Wax ang naka expose diba at naka tago si collinte.. so pano yung beading? beading ni booster wax ang e-effect? TIA
    Mar 2005
    #823
    Paano ba nalalaman kung wala na talaga yung wax?? Kumakapit na ba yung water droplets imbis na mag bead sa paint?
    #824
    thats what i'm afraid of.......
    Idol.... me susubukan tayo sa sun.... dalin mo yung vios...
    Boss, share nyo po yung effect pag nawasa yung ginagamit
    Aug 2009
    #825
    *madkatz
    Mam right now I'm doing an experiment sa 476S ko. Ang ginawa ko is
    1. Detail with 476S with NanoSLIQ. Kapag marumi or maputik, wipe with NanoSLIQ. Kapag iwawash, lagay ng SLIQ after.
    2. Detail with 476S only. Kapag marumi, dust off lang or hinahayaan ko. Rarely gagamitan ng NanoSLIQ. Kapag wash, wala ng ilalagay.
    Any thoughts/suggestions? So far I'm on #2. Medyo hirap lang ako gawin to kasi di ako sanay pumasok ng marumi oto eh hehe.
    Pero so far ang pinakamatagal na tinagal ng 476S sakin is 13 days. Double coat pa yata ito pero the 2nd coat was applied 2 days after the 1st coat. Ginamit kasi yung oto.
    hmmm 13 days is quite short for 476, im with number 2 though
    Aug 2009
    #826
    Quote Originally Posted by Ginnova View Post
    Also applied 476s 10 days ago and i think wax is still present. Pano ba malaman na wala na yung wax at kailangan na ulit patungan.
    one of the easiest way to tell is when the beading is gone
    Aug 2009
    #827
    Quote Originally Posted by Nik View Post
    it depends on the booster you guys are mentioning, if you're using OCW which is really a wax not a booster then it might take one OCW's water sheeting, but after some time it should bead again, if its Nano Sliq if would supposedly prolong the beading from Collinite
    Aug 2009
    #828
    Quote Originally Posted by jmpet626 View Post
    its quite hard to tell but it all boils down to water behavior it it doesn't sheet anymore or doesn't bead anymore thats basically it, but if it doesn't bead or sheet anymore it doesn't really mean there's zero protection left it might still protect a little but not as good anymore
    Aug 2009
    #829
    Quote Originally Posted by watusi View Post
    i think it all boils down to how hard the water is, there's some cases that even if you have left a few drops on the paint you don't get water marks and there are some cases where the water is really hard and it does affect wax durability, one of the easiest ways to check if you have hard water is to leave some on the rear window, and see if it marks
    Sep 2009
    #830
    Hi Guys,
    I filled a paint chip with some touch up paint, but I forgot to add masking tape to the surrounding area and messed up by spilling a layer of some touch up paint on the surrounding area
    I'm having a hard time removing it. I have found countless u.s. threads on google about langka blob eliminator that comes with the langka paint chip kit to remove touch up paint only without removing the clear coat and paint beneath it however I'm having a hard time finding this in the Philippines (at least online) yet its widely available in the US.
    I'm scared to use lacquer thinner as this might eat through the clear coat + paint beneath the accidental touch up paint area but if this will work I may try it. I have read some online threads about using sand paper (high grit) but I'm still skeptical if it will remove only the touch up paint and if it will make it worse with sanding marks.
    I just want to remove the top layer of touch up while leaving the clearcoat and base under it. Any insight or tips would be greatly appreciated and where I can find the product to remove the touch up paint only (ace hardware, blade, etc)
    I do have some meguiars ultimate compound but I'm not sure if this will work, want to check with you guys first on how I should proceed.
    Mar 2005
    #831
    Daming watermarks..
    Removed watermarks using a generic rotary, megs finishing pad and Optimum poli seal
    Applied DP Policoat paint sealant as LSP
    Will apply another layer after 24 hours
    #832
    Daming watermarks..
    Galing sir!
    Mar 2004
    #833
    Quote Originally Posted by informant View Post
    I was able to buy a Langka Paint Chip kit from Autoplus (EDSA) back in 2005. You may want to call them up and ask if they still have it, or know how to get it.
    How long has it been since you've applied the touch up paint? Langka kasi works best if the touch up paint is less than a week old. If left to cure for a longer time, it will have a harder time getting rid of the excess paint.
    Jul 2006
    #834
    Daming watermarks..
    Nice JMpet. Kung ganyan din kalaki at kaganda parking namin, wala sigurong days na madumi lahat ng sasakyan namin.
    #835
    Quote Originally Posted by dotnetmatt View Post
    nice jmpet. Kung ganyan din kalaki at kaganda parking namin, wala sigurong days na madumi lahat ng sasakyan namin.
    +1.........
    Sep 2009
    #836
    Quote Originally Posted by ess View Post
    Thanks for the reply bro. It's been less than a day or a day at most. I tried calling them but they have no idea what the langka paint chip kit was, had to explain to them it was a paint chip repair and remover but they don't seem to know it.
    I guess I will try later to use rubbing compound to see if that will remove the touch up paint.
    #837
    Daming watermarks..
    Wow! nawala water marks!
    #838
    Quote Originally Posted by madkatz View Post
    care to explain why number 2? padating na rin kasi ung 476 ko. hehehe. thanks
    #839
    I used Moms Step 1 to remove the water marks form my hood. After applying and rubbing gently with my finger, i wiped it off with a microfiber cloth. I did this for 3-4 times because the stain was pretty hard to remove. I also noticed that the red shade of my car where i applied step 1 wasn't as bright as the area where the chemical wasn't applied. After appying moms step 1, i applied NAno Glos and the color went back to its original state. Did I just damage my paintjob by applying multiple times? Will the dullness of the paint return once nano glos fades off?
    The instructions states that I should only use this 1-2 times a year. When I did the multiple applications, did I just simulate 2 years worth of application?
    #840
    sa pagkakaintindi ko sa instructions ng mothers, yung 1-2 times a year reffering for the maintenance interval.
Detailing Thread [For Newbies][continued]
