Originally Posted by
madkatz
Hmm well there is but its not worth it anymore, if its a little dirty with grime as long as its grime and road film its ok, meaning if its something like an oil film then just leave it be, as long as there are no other grits that you can see and feel you should be safe, you see its really really hard to remove road grime, imagine, that would be like removing an invisible layer of tar or grease from your paint, so im quite sure no shampoo would be that strong to remove those except for decontamination systems which are also expensive, if i were you i would just leave it and don't bother with it, apply the wax, some waxes have solvents in them that might remove them in the process thats why your applicator pads turn black after some time, its not because you didn't wash your car properly its because it had road grime, and then lets say just wait for the quarterly or bi-annual pre-wax cleaning step, its a good practice to use cleaner waxes every other month and cleaner sealants quarterly and if you're layering multiple layers then you could also delay it to bi-annually
The active effort to remove road grime and these road films every time you accumulate them is honestly a bit pointless for me, even for us who detail cars, we don't usually bother that much with our cars with road grime, why? because you could get a thick layer of road grime even if it doesn't rain. If its rains however the water helps to act as a medium from the road and smoke to the paint thats why raining can really increase the amount of road grime on the paint, but even if its not raining, try following a bus for some time, or try to travel through Edsa for 4 hours, you should already collect enough road grime turn your applicator pad grey thats why we usually don't bother with it anymore just as long as its not gritty
