Page 72 of 83 FirstFirst ... 226268697071727374757682 ... LastLast
Results 1,421 to 1,440 of 1650
    Jan 2010
    #1421
    Quote Originally Posted by watusi View Post
    IMO, Better if SwirlX+IPA(alcohol rubdown)+915.
    wax po ang nano gloss which has great filling capabilities
    Ok sir, thanks for the suggestion. May proper procedure po ba ang IPA rubdown? Thanks
    #1422
    Quote Originally Posted by Louie_18 View Post
    TO be sure that swirl X will be removed, you may spray a portion then wipe dry
    #1423
    *SG dapat back job yan...anyways, pero minsan ganyan talaga, nothing beats the machine painting nung asa factory pa lang ang auto. mahirap na ibalik sa dati. ganda p din ng tucson mu! pa-experience naman. hehe
    *all magkano clay bar? pwede ba magclay ng mags? hehehe trip lang. dumi na kase e
    Jan 2010
    #1424
    Ok bro, thanks. i'll do this on Sat
    #1425
    Quote Originally Posted by aejhayl17 View Post
    1k kuha ko, Source Chemical yung brand. im not sure about the weight.
    according to master, it's ok to clay mags. just be sure to use old clay para hindi daw sayang yung clay.
    #1426
    parang i remember nga na sabi niya dati yun. thanks bro. anyways, try ko muna i-kerosene therapy yung mags ko, baka makuha pa.
    may touch up paint ba sa big berts?
    Jul 2010
    #1427
    sir para maka mura .. bumibili ako ng mothers clay bar set 1.3k tapos ibebenta ko yung QD ng mothers na kasama sa set ng 600 pesos or 550 pesos so lalabas nasa 700 pesos yung bili mo dun sa clay with MF towel pa hehe so kung bebenta mo din yung MF towel ng 100 so nasa 600 lang yung clay.. good for 2 years na yun kasi 2pcs yun andun isa kada taon ehehe
    Aug 2009
    #1428
    buong car daw na compound nila, naka lagay
    Rubdown whole body.
    Napansin ko rin kasi hindi madulas yung whole body tsaka nabawasan yung kintab na inaalagaan ko e.
    Lintek na buhay 'to
    Hmmm whats crazy is why did they use compound on the whole body if only a few panels are being worked on, you could tell them that nothing beads true blue OEM clear coat and they should do their best to make it right, its bad enough they already reduced your clear coat and making the right color match and make sure the finish is 100% perfectly clear would be the least damn thing they can do, you didn't authorize them to use compound on the whole body so why did they go ahead and do it? going against protocol? then at least make sure they finish the compounding damage they did
    Aug 2009
    #1429
    Quote Originally Posted by rico_g View Post
    hayop ang casa.... kung ako yan, I will demand that they re-apply a fresh layer of clear coat.... di naman pwede un na they disregard what you so heavily preserve...
    yup up with this
    Aug 2009
    #1430
    Ah so yun pala yung main difference. Siguro pwede na rin yung 7424, pero mahal ba yun for 7K?
    Hindi naman daw abused. hehehe..
    Titingnan ko kung ano kalalabasan. Gusto ko ipa wet sanding sa kanila then compound, polish, finish.
    Pag hindi parin maganda kinalabasan, repaint nila yun bwiset.
    it depends on the inclusions, is the 7k for the machine only? if the unit still looks like new and still performs great then its not a bad deal i guess although i would still recommend you just get yourself a new one
    Aug 2009
    #1431
    More pics of their epic failure..
    Issues:
    - Hindi masyadong pulido yung pagkaka polish.
    - Marami pang sanding marks.
    - Kita pa yung micro swirls from Rubbing Compound.
    - Medyo malabo pa yung clear coat.
    - Magaspang yung whole body.
    - Hindi na-sand or Buff yung door handle bowl.
    - Halata yung putol ng painted part sa rear quarter panel.
    Orig Paint:
    Repainted:
    What can you say Miss madkatz?
    Thats what i call a hack job!
    Distinction of image is gone!
    Clarity of paint is gone!
    Obviously slickness and smoothness of paint is not present!
    Color matching didn't match!
    As with the door recessed part of the handle they should at least try to polish it down by hand with some mild polish until its clear
    At first i thought it might just be caused by the different lighting of the picture but once i saw the rubber and plastic trims and compared how light hits them its pretty obvious the color is really different
    Aug 2009
    #1432
    Nyeta kasi
    Kung may gamit lang ako dito like PC7424, Orange cutting pad at Mothers Machine Glaze, Mothers Foam Pad Polish.
    Siguro sinubukan ko nang gawin yan
    Actually in most cases repainted parts are really quite hard to match with the paint but most are barely visible to the untrained eye, but this one doesn't take a trained eye to distinguish, then again the lighting is also different
    Aug 2009
    #1433
    Bale 6 Months naman yung warranty bro. Pwede ibalik ng ibalik basta may reklamo.
    Pag napikon na ako, ipapa strip to metal ko na yan sa kanila.
    i would suggest you bring it back
    #1434
    Damn
    I want to print this page and show to their faces tomorrow!
    Ngayon alam ko na lahat ng Casa kulang sa training ang mga workers. If not, tamad yung workers. Hindi nila alam kung ano ang tama at mali.
    Thank you very much Ms. Madkatz
    Aug 2009
    #1435
    Quote Originally Posted by Hardinero View Post
    question mga idol...especially ms madkatz our guru..
    in combo waxing
    cleaner wax needs finishing wax...
    pwede bang ganito cleaner sealant tapos finishing wax
    also, cleaner wax tapos finishing sealant
    Cleaner wax is best when topped with finishing wax
    cleaner sealant is best with a pure sealant
    cleaner sealant can be used with a wax on top but some cleaner sealants require curing time although 90% of them don't
    using a cleaner wax and top it with a sealant however would be pointless because of the oils of the wax making the sealant bond less with the paint
    Aug 2009
    #1436
    actually, I was interested in this as well... ok na bargain na rin kasi... a bnew PC would cost $129 = P6.3K plus state taxes and shipping, it's like buying a PC in the US without all the hassle...
    sabi naman dun sa link ni watusi, the difference is just the addded 20% efficiency, so 7424 can still do what the XP does...
    hmm aside from the added 20% in power another bonus of the new XP is the heat reduction of the machine under load, the machine was upgraded with a more powerful motor along with proper wiring for it to be able to handle more pressure under load without heating too much, so if with a 7424 you can polish for 4 hours straight before reaching X degrees it would take about 5 to 6 hours before the 7424xp reaches the same temperature so this makes the 7424xp also in some ways more durable
    Aug 2009
    #1437
    Oo nga e. Kating-kati na ako mag clay.
    Pero yung mga parts na halatang palpak, kailangan nila gawan ng paraan yun.
    if they still can't get it right try to contact my BF he might help you with it
    Aug 2009
    #1438
    Guys,
    I'm planning to apply swirlX sa hood ng black Innova ko. Madami na kasing visible na light scratches and swirls. Pano ba mag-apply ng swirlX by hand safely and sa hood lang naman? Saka ok lang ba mag swirlX kasi more than a month plang yung sasakyan? And after swirlX ano pong recommended nyo na pang polish? Thanks!!!
    hmmm if i were you the first thing i would recommend is to try and notice where the swirls are coming from, is it coming from washing techniques? if yes then practice the two bucket method properly first before you correct the paint, if its not caused by washing then try to isolate the root cause of the swirls and then do something about it before you correct the paint of swirls, this way if the paint is correct and swirl free you would have a longer chance of preserving that perfect finish for a longer time, one thing i don't really agree with is that most people actually have their cars detailed twice a year to remove swirls not knowing the these swirls can easily be avoided just by proper washing techniques but if you really can't stand it anymore then i would say go with it, After swirlX you could try Megs Step 2 to add a little more pop
    Aug 2009
    #1439
    Thanks sir So after swirlX sir I can already apply 915? Ang Nanogloss po ba anong category, polish?
    after swirlX yes you could proceed to 915
    Nano Glos is somewhere in the cleaner hybrid wax/sealant category
    Aug 2009
    #1440
    i think edwin sells them for 1k but im not sure, he has some upcoming claybars from a known company but is still not yet disclosed try to watch out for it and yes you could clay mags although i would suggest you use really old clay bars for that
Detailing Thread [For Newbies][continued]
