Originally Posted by
indiej
watusi,
strip the sealant and wax separately. every 6 months for the sealant, up to you how often to strip wax. this is where the method you use gets tricky cos you might inadvertently strip the sealant when you only want to strip the wax. know thy detailing products.
some people also use citrus wash or diluted dishwashing soap
don't worry too much about thinning your clearcoat, you have 5 or more compounding sessions 'til it's in danger. the prewax cleaner is lighter than a rubbing compound as long as you're not hand rubbing it heavily or using a rough applicator/buffer. AND if the CC does fail.. Opti-coat.
isopropyl alcohol (IPA) wipedown is at 1:1 dilution. use more IPA when wet. some use IPA straight.
