Results 2,311 to 2,320 of 2535
- Nov 2014
- 1,269
June 10th, 2017 02:06 PM #2311Guys, how do I remove paint transfer? Pagbalik ko kasi sa parking may dumaplis sa fender and bumper ko. Fortunately mukhang walang gasgas pero may nagtransfer na white paint. Nagfall-off na yung iba pero may konti pa na natira.
June 10th, 2017 02:43 PM #2312
I use polishing compound. Pag di nakuha rubbing compound na
- Feb 2017
- 164
June 11th, 2017 10:09 PM #2313
- Aug 2012
- 2,767
June 12th, 2017 11:00 AM #2314Sharing some photos of the Dual Action Polisher Pro v2.
Unit is supplied with 220V plug so there is no need to use 220V/110V step-down transformer unlike the machines from USA. Unit has full CE/GS certification. The Dual Action Polisher Pro v2 offers all the features of the more the expensive machines at an affordable price.
What's inside the box: 1x DA Polisher Pro v2, 1x 5" Backing Plate, 1x Handle, 1x Foam pad, 1x Wool pad, 1x Wrench, 2x Carbon Brush, 1x User Manual.
The 6-speed selection knob on top allows you to select speed on the fly from 1800-7000 OPM. With a powerful 800W rated motor (1200W peak), it is possible to remove scratches and swirl marks. It is also perfect for applying glazes, sealants and waxes.
The large power trigger switch allows you to turn on/off the machine instantly. Built-in electronic soft start function protects the equipment, the user and the car's paint. The machine spins slowly at start, then speeds up to your target speed level.
The power lock button on the handle can be used to keep the machine running so you do not need to keep pressing the trigger switch. Simply press the round button to lock the machine. Press the trigger switch anytime to release the lock mechanism.
The ergonomic design allows for precise paint correction with complete comfort, including curved surfaces and difficult to reach areas. The handle can easily be placed on left or right side depending on the preference of the user.
Dual action polishers are very popular with car enthusiasts and professionals alike as they are low risk (will not harm the car's paint) but gives much better results than polishing by hand. In other words, the machine is idiot-proof.
Sent from my ASUS_Z010D using Tapatalk
- May 2012
- 372
June 12th, 2017 05:30 PM #2315^ May i ask, where to buy this and the price tag?
Sent from my ASUS_T00I using Tsikot Forums mobile app
- Aug 2012
- 2,767
June 12th, 2017 08:25 PM #2316Available from D3 Technologies. P8,500 for the full set.
D3 Technologies - Home | Facebook
- May 2012
- 372
June 12th, 2017 10:43 PM #2317^ thank you sir red one.
- Aug 2010
- 117
June 20th, 2017 09:14 PM #2318I need your advise mga boss, bumili ako ng Meguiar's Hot Rims All Wheel Cleaner for my wheels (honda city vx 2015 stock rims) Sabi sa specs. its alloy wheel. Safe ba gamitin yung megs na binili ko sa wheels ko?
- May 2017
- 572
July 5th, 2017 06:32 PM #2319I've been religiously washing then waxing with collinite 845 once a week for the past month... Then I just purchased Meg's ultimate liquid wax which is a paint sealant. Can I just start using it after my carwash this weekend? Or do I have to clean and remove all the wax that I put on the car before?
July 5th, 2017 07:03 PM #2320
Are mandatory seatbelts, and minimum brightness standards for exterior lighting also woke elements?
Carbon fiber hood
