Results 2,251 to 2,260 of 2535
July 22nd, 2016 01:18 AM #2251
Megs white wax is not too common here, you have a hard time getting feedback from this forum. But you are looking for cleaner wax specific for a light colored paint, it's worth a try, it will definitely amp up the shine, since it contains abrasives found in megs ultimate polish. Just dont rely too much on the protection, durability is not the strength of cleaner waxes, i suggest you follow it up with a more durable wax or sealant.
- Dec 2014
- 25
- Jun 2016
- 33
July 28th, 2016 11:29 PM #2253Hi, anyone of you tried glaz stainz out and stainz guard? how do you apply it? Do i need to shampoo my window first? Thanks in advance
- Aug 2012
- 2,767
July 29th, 2016 07:49 AM #2254
- Jun 2016
- 33
July 29th, 2016 08:35 AM #2255
July 29th, 2016 08:51 AM #2256
It will work better on clean windows, it is not an aggressive watermark cleaner, you will need to put in some pressure to make it work, if it dries, just spray water and rub it in again until you see your desired results.
July 29th, 2016 11:53 AM #2257
Ano pwede pantanggal sa already hardened cement? Medyo matagal ako hindi nakapagcarwash then nakita ko on lower part paglinis ko may matigas na talsik ng cement, hindi na kaya ng gaas. TIA
Sent from my SM-G920F using Tapatalk
- 54,304
July 29th, 2016 11:57 AM #2258
July 29th, 2016 08:19 PM #2259
July 29th, 2016 09:55 PM #2260
Cons, masarap sa mga daga.
BYD Philippines
