Results 2,141 to 2,150 of 2535
- Oct 2015
- 99
November 14th, 2015 05:58 PM #2141Thank you red_one.
Check out ko yung drill kit.
Pero kung ang purpose ko lang pakintabin yung car. Ok na ba yung low power?
Nabasa ko somewhere na pwede ko daw ma tanggal yung clear coat and paint kung di marunong gumamit ng high power na polisher.
November 14th, 2015 07:06 PM #2142
- Apr 2015
- 104
November 14th, 2015 07:57 PM #2143[QUOTE=red_one;2644185]OLX seller name: D3 Technologies. Contact # 09176775587.
Thank you sir. Same ba sya ng Meguires drill kit na dual action?
- Aug 2012
- 2,767
November 14th, 2015 09:54 PM #2144They are similar but not exactly the same. Both attaches to electric drill.
Meg's DA system is dual-action, 4" in diameter and comes with 1pc 4" regular flat foam pad. It is more expensive at US$59.99. You need to spend more to buy additional pads. Compounding pad costs US$13.99 per set. Polishing pad costs US$13.99 per set. Waxing pad costs US$13.99 per set.
The other drill kit is 5" in diameter and comes with 3pc Hex-logic pads: 1 for compounding, 1 for polishing and 1 for waxing. No need to buy additional pads upfront. It is not dual-action but no worries, just control the speed of your electric drill. Use low speed while learning to use the kit and adjust later on pag sanay ka na.Last edited by red_one; November 14th, 2015 at 10:00 PM.
- Aug 2012
- 2,767
November 14th, 2015 10:28 PM #2145That is only true if you are using high power, rotary buffers na designed for professional use. Tapos you just keep the tool in one place. For sure, sunog ang paint mo.
Re: low power polisher. If purpose mo lang is pakintabin ang car, then okay sila gamitin. But later on, when you want to remove scratches, remove water marks, remove swirl marks, polish glass, restore headlight lens, then you need to invest on another tool.
Re: DA action polisher. Good to have if you detail your car often, like monthly or own several cars. Pricey nga lang sila. China-brand DA polisher already costs P7,500 with 1pc 6" regular flat foam pad. The better brands (Meg's, Porter Cable, Griots Garage) costs more than P12,000 locally and 110V pa sila. Need transformer to use them.
November 16th, 2015 09:20 AM #2146
for drill adapter kits , use them with caution specially if your using high speed drills. you can easily burn paint . most drills have max 3000rpm. At these speeds it will only take a few seconds for the paint to get burned.
- Aug 2012
- 2,767
November 16th, 2015 12:48 PM #2147Re: drill adaptors. With the right knowledge, there is nothing to be scared about.
1. Use the CORRECT pad. Example, the black Hex-Logic pad is a super fine finishing pad that has NO CUT. You can use it safely for WAXING.
2. Use LOW speed while learning to use the kit and use LIGHT pressure. You can increase the speed and pressure once sanay ka na. You just need low speed for waxing anyway.
3. Keep the tool moving. DO NOT keep it in one place. Specially true when COMPOUNDING using cutting pads.
- Aug 2012
- 2,767
November 20th, 2015 05:23 PM #2148My new tool - 6" Clay Pad. Para mas mabilis magtanggal ng embedded contaminants, watermarks, etc. Can be used over 60 times. Just rinse with water to clean the pad. For hand use or machine use (DA polisher or drill kit).
- Nov 2015
- 11
November 28th, 2015 01:02 PM #2150
Detailing gurus kakabili ko lang ng makita na buffing machine gusto ko kasi matuto. Pag papractisan ko yung luma Kong oto maraming gasgas para di ako manghinayang if masunog o madamage ang paint. Practice muna bago ko ipa washover.
Question lang, anong magandang product ang gagamitin?
Ok ba ang microtex nanofil to nanosliq?
Or mag mothers nalang ako step1 to step3?
Ito lang kasi available dito sa province thanks
For the most part, he's ok. Except for the way he tests the film strengths of motor oils using the...
Liquid tire sealant
