Page 67 of 127 FirstFirst ... 175763646566676869707177117 ... LastLast
Results 1,321 to 1,340 of 2535
    May 2005
    #1321
    Quote Originally Posted by yourman_2nd View Post
    i'm using collinite 915 for the rainy season and i noticed that it doesnot prevent watermarks from forming on the roof and hood. i even applied nano slick after 12 hours to double the protection but still, watermarks are left on the hood and roof after raindroplets dryout. ano ba magaling than collinite 915 na LSD/wax that prevents watermarks (that is available locally)?
    Hi sir. Did you polish your car first before applying the 915 to take out the watermarks? Maybe it was there in the first place and got locked in with the 915. And there is no magic product that will prevent watermarks. Given that rain water is acidic, it eventually eats through the layers of waxes we apply until it reaches the surface finish. Its further aggravated by the intense heat we have. Only way is to not let rainwater dry up sa sasakyan and just wash it at the end of the day. Nano sliq offers no protection at all sir. The 915 by itself is very durable and highly praised for its durability. You have a very good lsd already sir. Paint prep lang yan and maintenance especially now na intermittent weather natin and extremes pa.
    Aug 2004
    #1322
    I use 845 and I haven't noticed watermarks. There are circular dust marks left after the water dries but I don't mind them that much because they just wash away the next time the car gets wet.
    Aug 2008
    #1323
    Quote Originally Posted by timykoo View Post
    Im using stainz guard as well. But not quite happy with it. Nagsskip minsan eh. I dont know if it's because im using cheap banana wipers. Btw, lumilipad lang mga droplets like mga 80-100kph pa.
    Try cleaning your wipers with isopropyl alcohol (no moisturizers) - this will strip the old, degraded outer layers of rubber, and might help improve wiper performance.
    #1324
    Can anyone point me to where I can buy the Klasse twins locally? I checked a Sulit and ubos na raw. Called Big Bert's Araneta and they said they don't sell raw.
    Due to the current weather conditions, I badly need these.
    Thanks for your help.
    #1325
    Quote Originally Posted by umi001 View Post
    Applicable ba to sa bagong refill ng wiper sir? Nag apply kasi ako rainx at bago yung wiper ko, nagjujudder padin hehe...medyo palyado pa nga yung refill, manipis masyado di swak sa clip.
    Jul 2013
    #1326
    good day po sa inyo mga sir.
    di ko po ma search yung thread regarding sa ganitong problema
    any idea kung paano po maalis mga mantsa na ganito? dati naman po naaangihan yung kotse sa garahe pero di nagkaka ganyan. paggising ko nitong umaga ganyan na. still original paint pa po yan
    hugas with car shampoo - ayaw matanggal
    wax - ayaw pa rin matanggal
    polishing compound - ayaw pa rin
    3m rubbing compund - ayaw pa rin
    hugas with ariel powder -ayaw pa rin
    kuskos gamit ang gaas - ayaw pa rin
    kuskos gamit ang diesel - ayaw pa rin
    buhos ng mainit na tubig tsaka kuskos - ayaw pa rin
    sobrang desperado ko kung ano ano tuloy ginawa ko
    Oct 2008
    #1327
    Di yan kaya ng detailing, ngunit naniniwala ako na "walang matigas sa kumukulong tubig"
    sa Usapang Pintura mas makikilatis ang ganitong problema. Kalabitin nyo sina dexter,raul et al.
    Ibang klase, pantay kasi sa ibabaw, walang makitang crack, sa ilalim nagkaproblema. Nakakita na ako nito pero bitak bitak ang ibabaw dahil bukod sa crack natanggal na ang ibang pintura kaya mapa mapa.
    Anong kotse at ano kaya ang history ng pintura nyan? Itanong na sa mga pintor yan.
    Aug 2010
    #1328
    Adam's Paint Correcting Finish -> Adam's Paint Finishing Polish -> KAIO -> Dodo Juice SNH.
    And yes, the surface is dirty as evidenced by the dirt at the center of the droplets. Poor beading due to dirt? Nahhh...
    #1329
    How do you guys remove air freshner odor from the car?
    I read na yung baking soda is just a myth daw? Are there any detailing product that can remove the odor and not just mask it? Thanks
    Oct 2008
    #1330
    one time fresh fish was left for a day , a sack of charcoal left in the car for a week and cleaning the damp mess solved the odor problem. didn't have to do anything mechanical to parts that smell but not dampened. the car still was used regularly.
    there are other chemical or enzyme based substances that can break down foul odors. try one from microtex
    #1331
    Quote Originally Posted by indiej View Post
    Guys I have bnew microtex washmit and waffle weaves. Pm me. Will sell very cheap
    Sent from my GT-I9082 using Tapatalk 2
    #1332
    Quote Originally Posted by allenjo View Post
    yes sir, used Mothers step 1 & 2 before i applied the 915. sometimes, when the car goes thru rain in the morning going to office, i cant help but let it dry sa parking ng office. come weekend, when i get to shampoo the car, ayun, ayaw maalis sa shampoo. kelangan cleaner wax or steps 1 & 2 again.
    Aug 2008
    #1333
    Agree - that looks like a problem with the paint itself, and doesn't seem like anything that can be fixed by detailing. It's almost as if the clear is "delaminating" from the base color layer...
    Aug 2008
    #1334
    That's really a problem that you'll experience with all beading LSPs - to a greater or lesser degree - unfortunately. The industrial fallout and dust can easily combine with rain water to create either an acidic solution which then etches into the paint, or it can create a lime/cement-like slurry that then leaves hard-to-remove deposits on the paint. Opti-Seal seemed to be better at resisting watermarking than the Collinites, at least IME, but even that got left with a few watermarks that needed a paint cleaner to remove.
    Oct 2009
    #1335
    nabili ko sa HMR Pioneer kanina, Porter Cable 7424xp, 110volts. Mga master good buy na ba P3,990.?
    #1336
    Quote Originally Posted by gls165 View Post
    Ang mura ah. Bili ka na ng step down transformer with AVR para magamit mo na yan.
    Oct 2009
    #1337
    Quote Originally Posted by nivraarvin View Post
    meron na sir, kaya binili ko agad.
    Apr 2012
    #1338
    mura na yan sir, I think nasa 9k to 13k bentahan niyan. if I remember correctly, I bought mine last year pabili ko pa sa US nasa $148 yata...
    Jul 2011
    #1339
    2nd hand ba ito?
    Oct 2009
    #1340
    Quote Originally Posted by s10pao View Post
    2nd hand ba ito?
    brand new daw & naka seal pa nga yung white foam pad.
Detailing Thread [For Newbies][continued 3]
