Results 831 to 840 of 2535
- Aug 2008
- 965
July 20th, 2012 07:10 PM #831
- Aug 2008
- 965
July 20th, 2012 07:14 PM #832As always, least aggressive option first. If a wash does not remove them, you can try, in succession:
1. non-abrasive chemical cleaner (Klasse All In One, Meguiar's Deep Crystal Paint Cleaner)
2. mildly abrasive cleaner or polish (Mother's Pre-Wax cleaner, Meguiar's Ultimate Polish)
3. medium abrasive polish (Meguiar's Swirl-X, Meguiar's Scratch X 2.0)
4. aggresive compound (Meguiar's Ultimate Compound)
Please don't use anything more aggressive than Megs UC (even that is a very aggressive product already) - you risk thinning your clear coat unnecessarily (and possibly dangerously) with old-school rubbing compounds. After you get the watermarks out, do protect your paint with a wax or sealant.
- Aug 2008
- 965
July 20th, 2012 07:18 PM #833Well, a proper three-step detailing consist of compounding, polishing and finish polishing. However, not all cars require all three steps - in some cases you might not need to compound; in other cases, the finish left behind by the polish is good enough not to warrant a finish polish. I'm not familiar with 3M rubbing compound - a quick search shows that there are multiple 3M products which are all called rubbing compound, some of which are for hand use only, some for machine use. My advice? Get the work done at a reputable place such as Big Berts, or hire a detailer to do it. (I can PM a few names if you want.)
- Aug 2008
- 965
July 20th, 2012 07:20 PM #834
July 20th, 2012 07:30 PM #835
Hmm, I have a 6-inch long scratch on the lower side of my front bumper. It's not in the underside so it's still visible from some angles, which is why I kinda want it removed.
My first option was to have it touched-up. I asked my friend how much it'll cost in their family's paint shop (The Wet Look), mga 3k daw.
Are there any other cheaper alternatives? Kung wala, I can leave it there. I'm just being a bit OC about it
July 23rd, 2012 03:31 PM #836
is it normal to still have remaining swirl marks after having a vehicle exterior detailing by a shop? 6 hours nila ginawa.
July 23rd, 2012 04:25 PM #837
July 23rd, 2012 05:42 PM #838
July 23rd, 2012 08:10 PM #839
wtf. sand the spiderwebs
jut, still try to touch it up. Best to use a bit of putty but if you don't wanna.. the process is clean, touch up, sand. Rinse and repeat then polish. When done, since it is very close to the underside it probably is noticeable only by you. If you can't then prepare your 3k.
July 24th, 2012 01:55 AM #840
It is repairable. But as oj88 mentioned, it is messy (when repaired) and best used as a last resort.
Liquid tire sealant
