Results 821 to 830 of 2535
July 16th, 2012 10:21 PM #821
- Aug 2008
- 965
July 17th, 2012 09:21 AM #822The Mothers line is a good alternative, and less expensive locally than Meguiar's. Again, haven't used it, but I've read good things about the new Mothers California Gold Synthetic Wax - reasonable price, has a nice darkening effect, and some cleaning ability. You can then top it off with your spray wax of choice perhaps at the next wash.
- Oct 2010
- 31
July 17th, 2012 01:23 PM #823
- Aug 2011
- 171
July 17th, 2012 09:08 PM #824Sumakit na ulo ko pag back read. Eto nakuha ko for best results na routine?
1. Wash car, dry.
2. Prep paint - depending on the condition of the paint, choose any of the 3 below.
a. clay (once a year or as needed?)
b. polish (twice a year or every quarter?)
c. apply pre-cleaner wax / cleaner wax (once or twice a month?)
3. Apply Sealant (Glaze?).
4. Let cure or on the next car wash, apply wax.
5. On the next washes, apply QD. Depending on the durability of sealant, wax, pwedeng ito lang gawin after washes.
6. An alternate is spray waxes after washes.
Yung #2 pwede rin skip kung good condition pa ang paint.
- Aug 2008
- 965
July 18th, 2012 12:00 PM #825Looks about right. For polishing, I would stick with doing it annually, at most - you shouldn't need to do it that often if you take care of your paint properly. I do always use a pre-wax cleaner of some sort before applying a new sealant/carnauba wax - just to remove any embedded dirt in the paint, as well any remnants of the old LSP, to ensure that the new product is applied on clean paint.
- May 2012
- 23
July 19th, 2012 01:30 AM #826mga master sa detailing ask po mga sir what the best gamitin para quarts brown na monty 3months old at my marka ng na tuyo sa harap sa may hood
TIA sa mag input
July 19th, 2012 12:36 PM #827
what are the "correct steps" in a 3step exterior detailing? was canvassing at a carwash, first step daw is 3m rubbing compound. want to verify if this is ok.
- May 2011
- 30
July 20th, 2012 12:28 AM #828mga boss, kaya po ba ito ng rubbing compound or kahit anung dent remover wax?
nakikita ko po ung parang itim na
di ko mapost ung pic hehe
July 20th, 2012 05:26 AM #829
- Oct 2006
- 261
July 20th, 2012 09:01 AM #830For the Klasse/Carlack you can try Extremedetail at Pinoydetailing.com. Send him a PM.
Are mandatory seatbelts, and minimum brightness standards for exterior lighting also woke elements?
Carbon fiber hood
