Results 791 to 800 of 2535
June 30th, 2012 09:15 PM #791
- Oct 2010
- 31
June 30th, 2012 09:46 PM #792HI guys, where can I buy the Klasse combo? I have a hard time looking for it.
June 30th, 2012 11:48 PM #793
None at Tru Value? There's also the Carlack combo that's the same with Klasse, just in case you chance upon them.
- Dec 2009
- 225
July 1st, 2012 03:02 PM #794Sir share ko lang tong ginagawa ko pang tanggal ng "Libag" sa kotse.. ewan ko kung safe pero wala naman me nakikitang negative sa ginagawa ko.. kinukuskos ko kasi sya ng nano gloss para mawala then spray ng nano slic.. eto po pix...
Yung red Circle yung nagamitan na ng nano glos, then yung blue is yung wala pang nano gloss
Nano Gloss
ayan naman po yung nagamitan na ng nano gloss kita nyo naman po ang laki ng nilinis nung may nano gloss na..
eto namna po yung kabilang side, tapos ko na po sya,, yung kabilang side naman po ang madumi.. umubos po ako ng 1 small bottle ng nano gloss for each side..
ask ko lang po kung ano maganda pang maintain para sa white color.. ok lang po ba yung nano slick? and yung mura lang po hehe ndi po ako gumastos ng lampas 500 para matanggal yung libag sa suv ko..
- Oct 2010
- 31
July 1st, 2012 03:02 PM #795
July 1st, 2012 03:34 PM #796
The thing about Nanoglos is just that just that it has very light cleaners. It doesn't even do even 80% of the job of your typical cleaner. White isn't white "enough" unless you've seen what a dedicated cleaner does.
If you're cash-strapped for KAIO, go for Collinite's Sapphire Wax. That way it cleans and protects (so it's a 1-step detail) na rin. I'm not sure of the prices though and you'd need a machine for it to work best. Check your suking detailer since William's Bluemile in Gilmore Ave. typically charges me around 800php for Wash + Clay + Sapphire + 845 on a 15% standard discount (pays to have connections :naughty2
July 2nd, 2012 06:57 AM #799
Mother's/Meguiar's Step 1 are pre-wax cleaners. Hmmm, your post count is ten times mine already. Which section in the forums have you been frequently helping out the tsikoteers?
Paolo, just to help you out of swirls, keep the detailing tools free from dust/sand/dirt. They're better off on a clean surface/container and not on the floor. The oxidation removal may be attributed to your mf pad and arm power.
You got a lot of good advice from the previous posts.
Does anybody know where to source a medium strength clay bar for paolo under 500 PHp?
Always test the whole process you've formulated on a small area. When you're satisfied with the time and effort used to get your needed results from a particular method, then go for the whole car. SwirlX or the stronger ScratchX by starting out light handed. Don't over exert the rubbing, ever.
- Feb 2012
- 41
July 5th, 2012 05:06 PM #800Sir,
tulong naman paano maalis ang mga water amrks sa car paint meron kasi mga water marks na hindi ko maalis specially sa hood. ano maganda pang alis ng water marks?
Though not on a people carrier like the Innova, I have Yokohama es32 equipped on my Sylphy since...
Finding the Best Tire for You
