Results 1 to 20 of 2535
    Aug 2008
    Quote Originally Posted by indiej View Post
    [SIZE="1"]i replied to this a while ago but i see it failed to post[/SIZE]
    pwede.
    siguro 8+ hours para tumigas ang 845 tapos Nanosliq ka na, ngunit bakit?
    ok rin pagmasdan ang kintab ng 845. kahit sa sunod mo nang paghugas mag-Sliq habang tinutuyo mo ang sasakyan
    Agree. 845 has a nice bright look, but isn't as glassy as NanoSliq. I actually like that bright look. Also, no need to boost so early, just use at the next wash - there's no reason to make detailing more complicated than it needs to be.
    Oct 2004
    Quote Originally Posted by umi001 View Post
    uy.. thanks mga gurus...
    i already applied it and i saw some improvements naman...
    so i guess its okay not to wait for the next wash... there was added gloss
    altho you may be right sir... 845 seems to be a durable wax...
    thanks thanks...indiej and umi001... :D
    and by the way... am just starting to learn pa lang...
    Aug 2010
    sir detailing newbie question: does wax can protect our paint from clouding?
    Oct 2008
    how do you mean? it might be clearcoat failure. if it's peeling, it needs a repaint.
    Aug 2008
    Quote Originally Posted by zap.FREEDOM View Post
    If the cloudiness is already there, as indiej said, it could already be clearcoat failure, which will require a repaint. If it's an old car with single-stage paint, then the outer layer of paint is most likely oxidized. The paint will need to be fed with an oil-rich glaze, and then the oxidized layers polished to reveal the good paint underneath.
    Now, if you're asking if wax will keep the "cloudiness" aka oxidization from happening, then yes, it should - oxidization is primarly caused by UV exposure, and both carnauba wax and most (all?) sealants offer UV protection to the paint, whether it be clear-coated or single-stage.
    Jul 2010
    sir, san nakakabili ng 845 aside from autobisyo?
    Oct 2008
    you may ask autobisyo, the distributor. big bert's has them before.
    Oct 2004
    Quote Originally Posted by air23 View Post
    yes sir... meron pa rin ata sa big bert's that's what it says... its P1200 ata... ;)
    Aug 2010
    Quote Originally Posted by jiggs84 View Post
    So it's 200 pesos more expensive than what Autobisyo retails?
    Aug 2008
    Jerome of Autobisyo does meetups in Makati. As already mentioned, Big Berts should have 845 available, as well as a place called PRAutoType Detailing - at least based on the list of authorized resellers on their Facebook page (not sure if you need to like their page first): Colinite Authorized Resellers
    Oct 2009
    Guys if anyone's looking for a [SIZE=4]Collinite Sapphire 73SS [/SIZE]wax, I still have one here. Just PM me.
    Dalawa kasi ung binili ko, hanggang ngayon wala pa sa kalahati ung binuksan ko. :D
    Oct 2009
    double post
    Oct 2008
    ..i already applied it and i saw some improvements naman...
    thanks by calling us just by our names. kung may sir pa, uwian na.
    good good. no problemo. aha, tumitikim pa lang :D so we're your enablers. mga kunsintidor for short.
    Oct 2004
    correct sir... este correct... pasensya na... nasanay na na merong "sir"
    subok lang mag-wax... hehehe
Detailing Thread [For Newbies][continued 3]
