Page 96 of 158 FirstFirst ... 46869293949596979899100106146 ... LastLast
Results 951 to 960 of 1575
    Mar 2007
    #951
    went to blade this lunch to buy mother's step1 and step3 and microtex nano glos. guy at blade said i should try mother's carnauba cleaner wax instead of the 3-steps. any feedback po from this item?
    i ended up buying magic 88 applicator pads, mother's fender wall brush and microtex nano sliq..
    Jun 2010
    #952
    Quote Originally Posted by raine View Post
    dagdag ko lang ng observation ko. dumating na ang pinabili kong 476 sa office mate ko na taga laguna.gamit ko sa black na tsikot. mga nasubukan ko para sa paint nito. TW hard shell, Mothers step 3 carnauva wax, 476 and carlack68 LLS,
    ito ang process na ginawa ko 3 coat ng carlack68 LLS - parang gatas ang texture , pinakamahirap ibuff, matigas
    pinatungan ko ng ibat ibang wax to test.
    TW hard sshell- mahirap i aplly ng manipis at mahirap din tangalin. ang effect minimum shine but madulas ang panel pag hinawakan mo.
    Mothers 3 step - madaling iapply ng manipis at madali rin ibuff, effect middle shine but merong mga whitish na naiiwan sa panel na kailangan balik balikan mo ang punas para matangal, di madulas ang panel pag hinawakan mo.
    476- madaling iapply ng manipis but pinakamahirap tanggalin or ibuff compare sa 2 wax, but masmahirap pa rin tanggalin or i buff ang carlack68 LLS, effect max shine and di madulas ang panel pag hinawakan mo.
    observe ko muna ang durability nilang tatlo, lahat ito nakapatong sa carlack68 LLS.
    476 will definitely outlast the two IMO.
    Jun 2010
    #953
    Quote Originally Posted by antz-z View Post
    AFAIK, carnauba cleaner wax is a combination of the 3 steps. if you don't have so much time for detailing your car, then go for the carnauba cleaner. but if you have time to spare on detailing, then go for the 3 steps, which i believe is more effective than the carnauba cleaner alone. I had the same thought before, but ended up buying steps 1 and 2, and 476 as the 3rd step.
    Mar 2007
    #954
    Quote Originally Posted by kafph2000 View Post
    thanks.. follow-up questions lang..
    mother's pre-cleaner wax is to be used 1-2 times a year, kaso wala naman nabibili na small amount lang. how long is the shelf-life of this?
    and also, where did you buy the 476? sa autobisyo website, it's P1900.. i thought it was only P700..
    Jul 2010
    #955
    Guys do you know how to take of an etched bird poop off a clear coat safely? I have tried searching here and on other sites but I can't seem to find the exact remedy. Because I was too desperate, I tried 3M scratch remover. It took off a little to none and made the clear coat hazy. Good thing I have the Hand Glaze to give it's shine back.
    So what would safely and completely remove the bird poop?
    Actually I had these in mind:
    -Bug and Tar Remover
    -Detailing Clay
    -Pre Wax Cleaner
    What would you recommend?
    Jun 2010
    #956
    I've read before na years din bibilangin regarding its shelf life.(probably 5? baka nagpalit ka na ng auto, buhay pa cleaner mo )
    Just make sure it's well kept in a cool dry place.
    700php parin yung 476 bro. the site is not updated. just bought one the other week and it's still 700 pesos.
    Mar 2004
    #957
    Quote Originally Posted by franster View Post
    -Detailing Clay
    -Pre Wax Cleaner
    ako ginagawa ko yung ONR spray lang yung portion na yun then wipe off...then another spray ng ONR para sure na wala maiwan...then QD...
    Apr 2010
    #958
    kakapit po ba ang collinite 476 sa paint kung mag aapply muna ko ng TW cleaner wax? or mas maganda pong shampoo ko muna ulit then deretso 476 na?
    sana mapadala na agad ng autobisyo order ko hehe..cant wait na kung maganda nga talaga yung effect ng 476 compared sa mga pinagpipilian ko before...
    Jul 2010
    #959
    Quote Originally Posted by dbhollanda View Post
    I think ONR is not effective anymore as the bird stain has oxidized already. How about for those severe cases in which the stain ate through the clear coat? Would it disappear if I would just leave it?
    Mar 2004
    #960
    true pag nag oxidized na e ibang usapan na talaga yan. di ko pa na try na ganyang case sa vehicle ko. antay natin ang mga reply ng mga masters/guru for that scenario.
Detailing Thread [For Newbies][continued 2]
