gurus, ask ko lang kung paano technique nyo on wheel wells kasi lately punas punas lang ako...eh may punas punas technique din ba sa wheel wells...
or talagang kelangan i-host siya...tas punasan na lang yung tatalsik sa body...
i came across din pala megs product. which of the two kaya ang ok..
Hyper Dressing
Water Based Dressing
may plastic nga pla infront nun wheel well ko..
mga idols question about pressure washers...
how does those portable pressure washers compare with those pressure washers with the motor and belts showing??? Thinking if i'm gonna buy a pressure washer from quiapo (the one with the motor abd belt showing) or just get one from ACE (compact looking)
this:
http://www.sulit.com.ph/index.php/vi...ressure+washer
vs
http://www.sulit.com.ph/index.php/vi...r#imageGallery
thoughts???
Question regarding wheel wells, safe ba ang kerosene na i-spray sa plastic part ng wheel wells? Dami na kasi dumikit na aspalto eh. TIA.![]()
hardinero, a simple way is to brush your wheel wells with soap, then add trim dressing.
i believe it was you who was advised to do the same and brushed out some of the undercoat in the wheel well areas and had to get re-rustproofed, hence you have more knowledge and experience about kerosene safety at the wheel wells than most of us. maybe you could give us more tips.
i think the undercoat is a type of asphalt so the stuck asphalt might be a welcome addition to it.Just brush with soap and apply your dressing.
it's safe to wipe (not spray) on the plastic part, but if you're the type who can overspread the kerosene to painted areas like the undercoat, hood, bumper, doors, etc., then be safe and don't do it.
kerosene is safe on my clear coat but its effectivity has a sweet spot at 15 minutes. It melts the asphalt but while it dries, the asphalt hardens again.
Hehe ako nga po yun.
Sa rear wheel wells ko po ginawa yun. Hindi kasi plastic yung wheel wells ng rear unlike sa front mostly plastic. And yeah asphalt nga yung rustproof/undercoat ng car natin so don't spray kerosene sa mga rustproofed part ng oto nyo. Noob pa ako nun.![]()
Para sakin mas ok yung Hyper Dressing kasi madami siyang dilution Ratio. Gamit ko parati 3:1 na ratio hindi masyadong makintab yung finish at tumatagal din yung kapit niya. Sa plastic wheel wells gamit ko yung brush na curved yung gamit sa pang linis ng CR at Megs na Super Degreaser. Pag sa rear naman na walang plastic super degreaser lang at pressure washer
Di pa po kami nagpapa-undercoat ulit. Anyway, isang part lang naman ng wheel wells yung natanggalan ko ng undercoat while the other parts naman reasonable pa yung undercoat nya. Manipis na pero meron pa naman.
Baka this summer pa-undercoat na kami ulit, update ko po kayo.![]()
