it's an All-In-One product, a shortcut to Steps 1 (pre-wax cleaner), 2 (polisher/sealant) and 3 (wax, either carnauba, synthetic or hybrid), great for light-color vehicles...
Good job, ildiej. So what's your conclusion from the wax comparo?
*GulongGong paps, parang ganito rin yung pag gamit ko..
kaya lang sakin eh sa hood and trunk ginagamitan ko pa rin ng light pressure..
tas yung chamois ko pang front,rear and side skirt ko na lang ginagamit..
kaya lang there are times talaga na medyo nakakatamad mag carwash like tonight kakauwi ko lang kasi grabe traffic eh 2 days na siyang madumi..hirap din kasi makahanap na ok ng carwash shop..
sir indiej, ok ba yung turtle wax cleaner wax? how often do you use it? pwede ba yun sa mga lights swirls and scratches? mas ok ba siya compared to mothers or megs cleaner wax?
Not indiej but i'll try to answer that
TW cleaner wax is a little more aggressive compared to its mothers and megs counterpart based on experience but being slightly more aggressive and abrasive may be good in some instance like what you've mentioned scratches, this cleaner wax can remove microfine scratches and is actually quite effective on watermarks due to the abrasives present, so basically to answer your question whether which one is better would depend on what problem you are looking to solve, for tougher defects and stains TW cleaner wax is better but for lighter stains mothers and megs would be better based on experience, but this suggestion revolves around the principle of saving as much clear coat as possible and avoiding using unnecessary abrasives to remove stains, as they saying goes start with the least aggressive method
*GulongGong paps, correct ko lang si yung sa hood and trunk...
agree with scharnhorst "slide the cloth on the surface of the car, let its own weight drag it along."
pero bro, before mo gawin yun. after mo kasi i-host down yun auto eh masyadong matubig yung kotse kaya para mapa-bilis yung drying time mo and para isang glide lang ng elite....IMO, patuluan o padaluyan mo muna ng tubig using the host yung roof,trunk and hood...para kunting tubig na lang matira...
I use it whenever I see water stains after drying the car. I make a few light passes over the stains and stain edges until they're gone. Then I buff it clean.
I don't use it for swirls and scratches. I don't have either M's cleaner waxes but i've read from the pioneers of the DTfN that they too work nicely.
*indiej: Great job on the car BTW, nothing beats a nice silver that looks spanking clean!
It's hard to avoid streaks when using spray waxes and touch up liquid detailers. IME, it's best to wipe it dry with a clean, damp MF towel.
sa OCW wala naman ako na experiece na streaking. I use the dry side of the mf towel para i buff off yung excess wax
may difference po ba sa shine kung 476 then nano sliq or nanoglos, 476 then nanosliq?
planning to buy kasi bukas ng nano glos pero kung same effect lang ng shine e di nako bibili...
medium silver altis po pala yung color
Question: pwede ba yung Zymol na qd na nabibili sa TV gawing clay lube?
