Ah, yung 'rainy days' promo pa pala. 476 lang kasi kinuha ko nun.
Pa-update nalang kami mga bro kung may sale ulit
Pero discounted narin pala yung 1.8k? Mapag-ipunan nga.. :D
476 and 845 are both basically the same, 476 being the paste version and also lasts about twice longer and 845 being the liquid version being less durable but easier to apply, basically looks wise they're both the same, 476 = hard to apply and PITA to remove but lasts really long, 845 liquid version = easy to apply, easy to remove, good for addicted to waxing and less just about half of 476
915 is on a different ball game in terms of looks, this baby easily wins over 476 and 845 two hands down and the durability doesn't go far down from 476 its nearly at par, basically what sets 915 apart from both collinite waxes is that the shine lasts longer
Its overkill because even with BB's Optiguard being suggested every 3 months you are also putting on a carnauba on top every other week or monthly meaning if you put Carlack twins every 3 months that should already be enough, but since you putting on waxes every month or every other week this would mean you're very concerned about your car's paint but putting carlack twins every month is taking it way over what is necessary
if the 915 would be removed from the wash process it will not be caused by the soap in the foam it would be the improper technique used by car washes around the metro, have you ever seen any foam type car wash around that also uses the two bucket method to remove the dirt and grits they remove from the paint? basically what they do it just push it around and hope the foam lubricated it enough to not scratch or marr the paint which in not what happens to most cases, improper washing technique as this could deplete any waxes or sealants ability to perform and protect due to the harsh nature the paint is being washed, its like they are being scoured out of the paint, but once done properly 915 would lasts a lot of washes because as SG said its detergent proof and it really is based on how many member here can attest to it
parang di nama over kill yung weekly wax.... I used to wax 3 parts of my car weekly.... using FLEET....![]()
I just use Megs UQW, Finish Kare 425, OGE between regular wax applications of about a month or so apart. Weekly waxing is not only expensive and time consuming but also unecessary especially if you have top wax/sealant brands already on. But if waxing weekly will put a huge smile on someone's face then, wax on!![]()
Sipag mo naman kung weekly waxing at monthly ang sealant. pwede yung weekly waxing
kung spray wax lang like OCW.
Question
gano tatagal ang 476 kapag walang pinatong na wax or kahit na ano..plain 476 lang walang nanosliq etc?wash lang ng once a week..speacially sa hood and dun sa may gilid(di ko alam exact word para dito sorry)
quick question lang mga sir ulit re: Cleaner Wax.
after ma-apply, may recommended next step kayong gawin? or puwede na yun lang?
TIA
Just an update on my MF towels that I soaked in vinegar/water mixture, soaked it for about 5 hours, pero di ko ginalaw, di siya naging soft. I think I have to soak it in lukewarm water before the vinegar. Pero I think yung medyo sa nakakapasong tubig ko na siya ibababad since matagal-tagal ng tuyo yung wax sa MFs.
Hi! Newbie here, ask ko lang po where to buy those Collinite, OCW, SwirlX that were mentioned in this thread. What combo would you recommend for bringing out the shine and detail of my car and to maintain it . Honda Civic '08, black. I currently use Simoniz Diamond Hard Wax once a week. Thank you in advance!
bat kaya ganon. ako kasi di na nga ako nagbababad sa lukewarm water e. ganto procedure ko...
- wash with water (faucet lang)
- laba with soap
- banlaw
- babad sa vinegar mix with water for 30 min. every 15 min turnover ko naman...
so far super lambot lahat ng MF ko...as in parang bago lahat...
