Quote Originally Posted by bombitmd View Post
jmpet, medyo madami yata gamit mo Ang technique ko for spraying OCW is slow squeeze, and while squeezing, swipe your spray over the area (ex., left to right). You just need a very light mist over the area you intend to wax.
For example, sa isang door ko, one spray across the top half, and another spray on the bottom half. Make sure lang na as your squeeze, you also move your hand so that the your squeeze will last the entire left to right movement. Gets ba? Ang hirap i-describe... hehe. Tingnan ko kung makagawa ako ng video
up with this one, thats what we also do, it all boils down on how you move you hands when you spray to ensure maximum coverage, even when using QD you don't have to use that much
