Results 331 to 340 of 1575
October 31st, 2010 10:56 PM #331
October 31st, 2010 11:52 PM #332
thanks for the headsup paps..
natanggal ko na siya bro...sinunod ko yung payo mo na hindi masyado lubricated yung clay..yun mabilis kumapit yung mga lisa..
dun naman sa vinegar on MF, tuwang tuwang ako dito kasi balik lambot and yung pagka fuschia nung mga MF ko....bili na lang ako ng distilled vinegar sa pasukan...
tomorrow mag 3rd coat ako ng 915...(nakaka virus itong thread na ito)...
pero ok na ito para ma-divert yun attention ko from getting CF hood and intake...waaa...pera pera...
October 31st, 2010 11:59 PM #333
yung clay bar ba ilang session na gamitan? anong lubricant ginagamit don?
November 1st, 2010 12:12 AM #334
November 1st, 2010 12:16 AM #335
November 1st, 2010 12:21 AM #336
Pwede nyo rin po hatiin sa dalawa yung clay para tipid hehe. That half clay bar can clay more or less 5 cars but it also depends kung sobra nang daming contaminants na nakuha ng clay.
Not sure kung pwede po yung Mothers nyo, spray wax po kasi yun eh. Anyway yung Zymol naman 150 pesos lang yun so you can consider that one.
November 1st, 2010 12:38 AM #337
- Jul 2010
- 172
November 1st, 2010 01:16 AM #338HI
. i'm still a newbie in this detailing so i have a few questions.
I was using 3M Auto scratch remover the past few months to remove very fine hair line scratch in the paint of my car. It did remove the scratch but left some very very very fine swirls due to the swirlings I did using the scratch remover. I also noticed that the area is not shiny anymore, even if after buffing - waxing -and buffing it again.
I've made some search here and come across some of the informations that GLAZE should hide those swirls and provide a wet look shine. Is GLAZE the same with POLISH? Which is better to use for a 4 month old car? Does GLAZE substitute the clearcoat that has been removed by the scratch remover?
What should I do next time after using 3m Auto Scratch Remover on some areas of the car where it has very fine scratches? or should I ommit using this product all the time when removing fine scratches?
What regimen should i follow to have a wet look shine all the time, and also have a lasting protection on the paint?
Sorry if I asked too much.
TIA.
November 1st, 2010 01:46 AM #339
November 1st, 2010 02:52 AM #340
if that's the case you should hit it with a less aggressive polishing product for the fine swirls. what color is your car? what did you use to apply 3mASR?
take pictures of a scratch. work 3mASR with an MF/foam applicator pad til it clears or almost dries. repeat til the scratch is corrected. take pictures of that area showing whatever remaining blemish you see. you should omit it if it really doesn't work for you.
you should do some backreading and get to the bottom of the steps and processes in detailing. you'll get a better understanding of what product to use.
then there's product specific knowledge, which is easier to read about in its own thread in certain detailing forums. then use the product and tell us how you made it work. or failed.
Cons, masarap sa mga daga.
BYD Philippines
