Page 6 of 79 FirstFirst ... 23456789101656 ... LastLast
Results 101 to 120 of 1575
    Oct 2008
    #101
    yes you can.
    i read klasse/carlack68 or something similar to that
    Oct 2008
    #102
    *Hardinero, thanks for mentioning carnauba cleaner. i found one in the old stock and tried it on dried water spots from the beading of 476s. It worked wonderfully. it took more effort and pressure with a QD & MF and was not entirely convincing.
    TWCC was waxed on foam applicator then wiped off with a short napped MF towel. a few light passes in WOWO, it was effortless and effective. later on i'll get a proper cleaner wax for Collinites.
    Apr 2008
    #103
    Quote Originally Posted by indiej View Post
    paps, is carnauba cleaner won't strip your 476? what nga pala yung proper cleaner wax for collinites mas ok kasi gamitin yung native product nya para bond properly talaga no..
    para yung cleaner carnuaba ko eh pang tanggal ko na lang acid rain..thanks for sharing din paps kasi last time ginamitan ko ng vinegar eh...mali pala yun..
    *PSI how sweet of you bro...bale paps, if di ko kinaya pero malamang kayanin naman...gulo no.....next weekend pa naman ako mag-start....buti pa kayo walang pasok sa monday...kami meron...waaa..
    Feb 2010
    #104
    Quote Originally Posted by Hardinero View Post
    eh doble pay ka naman eh....
    kung kaya ng 1-2-3..... dito naten sa labas tirahin yung wash/clay/1/2.... by hand nga lang.... tapos start tayo mga 5am..... tapos tayo mga ala pang 7am
    Jul 2010
    #105
    Quote Originally Posted by madkatz View Post
    actually 2 layers should already be enough if you're planning on maintaining it with waxes weekly, don't spend too much on multiple layers if its gonna be well kept and maintained, just try to save the product so you get more results longer with the bottle, actually if someone waxes his car weekly heck even NXT, Gold Class, TW PUG and Moms Step 3 and FX would already do the job. try to make the sealant work for you, keep it simple with 2 layers and then just relayer after a few months
    layering multiple sealant won't really guarantee you a perfect finish from the elements, check out my post last december when i had a multiple layer of sealants 2 layers m-seal and 2 layers KSG topped with 2 layers 915 and blitz acrylic spray sealant as topper, after i finished that setup i went to canyon woods feeling like nothing would harm my paint, then comes those pine tree saps that really etched into my paint, now if you think of it, i had a total of 7 layers all cured properly and boosted with polycharger and the tree saps still etched through, kinda hurts right? all the effort down the drain? thats why im telling you guys to keep it simple, 2 is enough, 2 more of another sealant would be great but if time is a problem with layering multiple layers then why work against time right? why not just apply it more frequently? all im saying is, if time and schedule really makes layering hard for you then just change your routine, you really don't have to do multiple layers especially since you're waxing already every week
    thanks mam sa tip.. so 2 layers nalang po is enough? kala ko max of 3 pwede. ginawa ko lang po na 4 layers everynight para makasigurado na may layer kasi po 12hrs curing time lang so i'm not sure if talaga bang kumapit hehe
    pero thanks po sa tip nyo dun sa drying time .. gagawin ko po yung test if ok na i buff para hindi sayang effort ko at para 2 nights nalang ako mag layer.. salamat po ulit
    tapos na board exam.. ma-haharap ko na ulit yung car
    Oct 2008
    #106
    won't TWCC strip 476s? maybe i can tell in a few weeks. did it strip 476s a little? maybe a little cos the water spots are gone. i just lightly ran the foam then waxed off. i think it's Collinite Sapphire Auto Wax but it could be a stronger wax cleaner.
    sealants require considerable time and effort to be effective (6 months protection in favorable conditions) hence my concern and wish to lessen the frequency of their application. i wouldn't sweat it with waxes.
    what madkatz said, there are just some natural substances that can etch through paint that need to be cleaned off the surface asap to avoid damage. no layer of any product can withstand it, the clearcoat sure can't withstand it.
    bird droppings here and there is ok, but if a week of sun-dried water beads does that, i better invest more on paint refinishing, say the next few 10Ts Php after 20T of detailing products.
    Jul 2010
    #107
    guys this week eto plan ko..
    suggestion guys before ko gawin para isang pasada lang hehe..
    wash - remove asphalt - clay - swirlx - megs step2 - Carlack68 NSC - carlack68 LLS (12 hrs curing time kasi gagamitin kinabukasan) - LLS again after gamitin yung auto (wash muna before LLS)
    aayusin ko na pag buff nung LLS para 2 application lang..
    by this week sana maka bili na ako kay master ng 476s
    Oct 2008
    #108
    Nik
    please make sure to wash off your asphalt remover
    delete claying and megs step 2.
    insert IPA after swirlx. For 70% Isopropyl alchohol, a 2:1 mix alcohol and water will do. spray the panel then wipe carefully with MF.
    #109
    Share lang..
    testing Moms Step 2 + Collinite 915. Hood only. hehe Black Tucson
    May 2010
    #110
    Share lang..
    bangis sir..
    Apr 2008
    #111
    Share lang..
    ganda ng depth paps.....ano yung steps 2 na gamit mo?
    Jun 2007
    #112
    *GS: dalawa pala tucson nyo... hehe. ano na pala nangyari dun sa crdi tuc ninyo sir?
    napadaan ako kanina sa autobisyo whilst on the way to santa rosa. parang nakakatempt yung souveran. hehe
    anyone here going to Rockwell later? hehe
    Apr 2008
    #113
    ms madkatz,
    1) for drying i'm using jelly blade muna para mabawasan yung tubig before ko i-wipe dry..
    would jelly blade cause swirl marks and can strip wax
    2) which is better between the two wash mitts yung sm arnold or microtex? yung microtex eto yung bilog bilog yung strand nya diba...
    thanks,
    hardinero
    Mar 2005
    #114
    Quote Originally Posted by scharnhorst View Post
    What time ba parang gusto ko din pumunta wala lang ako kasama
    #115
    doc Scharn: Hindi. Isa lang Tucson ko. hahaha Sa kasama ko yan sa Tucson.PH. Fellow Premium owner din siya. Pinag initan ko lang kasi black. hahaha
    hardinero: Mothers Sealer and Glaze sir.
    jed_015: Thanks.
    Jun 2007
    #116
    Quote Originally Posted by jmpet626 View Post
    punta ako mga 6 pm, sabi ni sir Ed morning till night daw yung sa Hillsborough
    #117
    Anong meron sa Rockwell ngayon?
    Jun 2007
    #118
    Magdedemo ata ng detailing yung Hillsborough sa mga exotic na auto. hehe
    Sep 2008
    #119
    VERY wise advice, as i just recently learned myself. A month ago, I put on a total of 5 layers of Zaino products on my black car. A week ago, I left the car in the dealership for an oil change. At the same time, I went out of town and came back three days later to pick it up. Que horror! the once china-smooth paint was now as rough as fine sandpaper. My skin made a horrible raspy sound when I swiped my palm over the paint. The wiper made a horrible sound on the windshield, too! I washed the car, but it didn't remove the surface contaminants.
    So I had to CLAY the car. And all those 5 layers of the month-old Zaino came off! And to think I was planning to keep it there for 4 to 6 months!
    I only reapplied 2 coats this time. Lesson learned.
    Apr 2008
    #120
    comrades, what are your thoughts on mothers powerball?
Detailing Thread [For Newbies][continued 2]
