Quote Originally Posted by jmpet626 View Post
Thanks. Will use APC na lang before washing the pad. Ano mas maganda dilution 4:1 or 10:1?
I would recommend you have both on hand, have a smaller bottle for the 4:1 however since you won't be likely to use this too much, 10:1 is already sufficient in most cases to remove residues from the pads especially if its attached to a rotary polisher, but there are some cases like some of the older megs polishes and waxes that really require degreasers to remove from pads
