Quote Originally Posted by madkatz View Post
with OCW you just use it like a QD but on a clean surface, you apply some on the MF first and about just one spray on the panel will do, this will already cover a lot of paint area
as with the Zaino question, it depends z5 can be layered immediately after doing the whole car and removing it from the whole car, once you done, you're ready to layer again starting from the first panel you previously layered, but this is best if left for 4 hours based on experience with the zfx, with Z2 if needs about 4 hours minimum for extended durability and 8 hours recommended, the producer says it can be layered immedaitely after doing the whole car but i don't that it doesn't stack as much when done this way
1. parang gusto ko itong zaino ah kasi mas maikli waiting time compared to carlack...pero ms madkatz which is better carlact or zaino..
2. kung mag double wax ako and 915 would be may LSP....ano yung base product (don't know the term to use, so pls correct me) na pwede ko gamitin before applying 915
3. kasi either this weekend or next weekend mag zero out ako...eto po steps ko..pls correct po
wash and dry..
apply kerosene to whole car (due na talaga especially the lower panel)
remove kero by degreaser and rinse again with water
dry again..
apply carlack AIO
apply long life sealant
wait for 24 hours (kaya I'm looking for a less curing sealant)
apply long life sealan (2nd coat)
wait for 24 hours
apply 915
after two weeks wash,clay,915
after weeks ulit wash, double wax (cleaner carnauba,IPA,915)
