Results 21 to 30 of 1575
- Aug 2009
- 1,553
October 13th, 2010 02:16 AM #21Hmm i would recommend you using claying first, if its still there hit it with at most 3 more passes, if its still there then you might need to try a more aggressive clay bar, if its taken out then just use a polish to clean the dulled surface, if its still there i would recommend you try this product but with moderate pressure only, no heavy pressures with this product, if its still there, get some shampoo and 2500 grit wet sand paper and wet sand the part and return the gloss with this product.
October 13th, 2010 02:37 AM #22
October 13th, 2010 04:22 AM #23
1. parang gusto ko itong zaino ah kasi mas maikli waiting time compared to carlack...pero ms madkatz which is better carlact or zaino..
2. kung mag double wax ako and 915 would be may LSP....ano yung base product (don't know the term to use, so pls correct me) na pwede ko gamitin before applying 915
3. kasi either this weekend or next weekend mag zero out ako...eto po steps ko..pls correct po
wash and dry..
apply kerosene to whole car (due na talaga especially the lower panel)
remove kero by degreaser and rinse again with water
dry again..
apply carlack AIO
apply long life sealant
wait for 24 hours (kaya I'm looking for a less curing sealant)
apply long life sealan (2nd coat)
wait for 24 hours
apply 915
after two weeks wash,clay,915
after weeks ulit wash, double wax (cleaner carnauba,IPA,915)
October 13th, 2010 04:32 AM #24
October 13th, 2010 04:37 AM #25
yung zaino kaya mabilis mag cure may ihahalo pa na zfx flash cure additive. Pag wala nun same din ng klasse yung curing time.
October 13th, 2010 05:44 AM #26
- Jun 2010
- 164
October 13th, 2010 07:00 AM #27I wash my car and use OCW twice a week... Wednesdays and Saturdays..
pero pag umulan, I'd either hose down my car, or do a waterless wash, tpos sliq...
I just had to get over the obsession for beading.... before kc it was my basis kung may wax pa o wala.... pero with OCW kasi, the beading is lost easy, but the look and feel of it, the ease of removing dust and the sheeting of the water shows that the wax is still very much intact...
October 13th, 2010 08:22 AM #28
October 13th, 2010 10:14 AM #29
for a fast curing LLS try to ask around for Polycharger H2O.
do you rinse before degreasing?
please check your claybar and cleaner wax against LLS. it's a great opportunity to experiment whenever the paint is bare of detailing products.
try on lower rear doors. doors are shiny even on a less detailed state when viewed at 30 degrees or less.
no need for IPA after cleaner carnauba.
October 13th, 2010 05:11 PM #30
paps, thanks for the headsup on the IPA..
ang gagawin ko paps, if ever na halimbawa feeling ko mag-expire na yung AIO and sealant...most probably in 3months wala na yung 2 coats no?
and if that happens tapos tinatamad akong mag sealant eh..double waxing na lang..
1) prep the paint by wash and clay
2) cleaner carnauba wax
3) 915
may nakapagsabi nga sakin re polycharger kaso mahirap ata mag-hanap..
Interesting thread—really important to consider the broader impact of the National ID Law beyond...
National ID Law
