Results 5,051 to 5,060 of 5910
June 24th, 2010 04:15 AM #5051
June 24th, 2010 08:45 AM #5052
sa wetsanding ng touch up paint ano po ba dapat yung grit ng sand paper? May mga paint chips na kasi yung jazz ko eh
June 24th, 2010 09:14 AM #5053
June 24th, 2010 11:20 AM #5055
June 24th, 2010 11:40 AM #5056
*azzkkr2600: balitaan nyo ako kung pupunta ulit kayo ha...
naiintriga ako dun sa optimum spray on wax
I'd like to up the query earlier... gaano katagal bago patungan ng nanosliq or kahit anong QD yung 476?
I just detailed our mz2... currently waiting at least 4 hours before I put anything else on top of the 476
June 24th, 2010 12:06 PM #5057
- Jun 2010
- 103
June 24th, 2010 12:18 PM #5058
- Jun 2010
- 61
June 24th, 2010 01:25 PM #5060This part Ive done before with excellent results:
1. get materials
a. let a local dealer mix a paint that matches your color, just a small bottle would do. (you don't need to take the entire car for them to mix the paint...just remove your gas tank cover and they can mix based on the color of that)
b. get a nail polish (what you would need is just the container). rinse the container thoroughly with acetone and let dry completely. take note not to remove the rattler ball, it will come handy when shaking the paint later.
c. fill the nail polish container with paint (the purpose of this is that you can have a touch up paint anytime you need, without getting it dry. also you will need the brush of the nail polish for applying.
d. you will also need sandpaper, I use grit 1200
e. solvent to remove dirt after wet sanding
2. lightly wetsand the scratched part...purpose of this is to let the touch up paint stick well
3. lightly clean the sanded part with solvent (not too much), let dry completely.
4. shake the nail polish container and apply touchup paint to the sanded scratched part using the nail polish brush (dont worry if it is a bit elevated). after applying paint, close the nail polish container quickly (paint dries fast, especially polyurethane)
5. let dry completely (i wait two days to fully cure)
6. wet sand after completely dry (by using any improvised sanding block, puwede piece of any hard level material then put sandpaper on top. do this carefully as you might get the surrounding clear coat to thin.
7. if you feel it is already level, polish with rubbing compound.
8. put wax for protection...
key is the paint mixture and patience in doing the procedure.
goodluck!
Balikan ko lang itong mga gumugulo sa isip ko kaya na-pa-reply ako sa thread na ito... was...
China cars
