Page 456 of 591 FirstFirst ... 356406446452453454455456457458459460466506556 ... LastLast
Results 4,551 to 4,560 of 5910
    Aug 2009
    #4551
    Sir wala pa po. Still waiting for updates.
    Default would really be his place since all the chemicals and stuffs are already there and until we find a larger place to accomodate all the cars then so far its his place.
    Feb 2010
    #4552
    Quote Originally Posted by jozep View Post
    UPDATE ko lang ang list.
    Detailers: Heads up!
    What: Detailing Seminar ni Sir Edwin
    When: June 14, 2010
    Where: His place in Caloocan. Please refer to the link below
    http://maps.google.com/maps?f=d&sour...1&ie=UTF8&z=18
    Head count tayo kung sino ang game sa June 14.
    1. Chikselog
    2. Dotnetmatt - Dimasalang near Chinese Gen
    3. ej (tentative din, wala akong gamit for the eb and shy ako )
    4. golti - Las Pinas
    5. beeco - Las Pinas
    6. jozep - QC (not yet 100% sure)
    Please update this list and list your name above if you're joining. Sir Edwin is asking for updates on how many will join. Thanks!
    As for the meeting place, wala pa po nababanggit si Sir Edwin if magme-meet pa or direcho na to his place.
    Quote Originally Posted by madkatz View Post
    Yeah sure! its open to everyone that has the will to learn about the basics of detailing
    thanks, pa add po me.......#7 psi - Marikina
    Apr 2010
    #4553
    Most probably you already removed the embedded minerals deposited by the water marks so yeah the next logical step would be to use ScratchX, i would recommend SwirlX if its not bad though because ScratchX is quite aggressive, its true that you would easily remove the marks and swirls with ScratchX but you also remove more clear coat in the process
    thanks alot for the info's... pahabol, how about for the watermarks of the windshield? rubbing compound? thanks again...
    #4554
    Quote Originally Posted by orange23 View Post
    I would suggest Elevo Watermark Remover. It's P280 only and you can find it in your favorite hardware stores. Just be careful in using this and be sure to wear gloves (the package says so) because this is an acid I think, judging from the smell.
    *madkatz
    Alright! Thanks for the clarification.
    #4555
    may bago ako burden....
    Night Hawk Black
    hirap i-detail nito
    #4556
    Night Hawk Black
    hirap i-detail nito
    Hehehe. Dyan ka nga makakapag practice eh.
    Aug 2009
    #4557
    *madkatz
    That would be a cheap alternative to removing waterspots on the windshield, but thats just for moderate to light, for heavy duty ones you actually need to use a Glass Polishing Compound, and yeah the Elevo uses acid in their kit as with glass polishing compound, actually nearly all water mark removal system incorporates acid to remove water marks its just a matter of how strong the acid is, if you've tried the acid for aluminum brightener the one i think you guys used on the engine detail, you actually use the same acid for Glass Polishing
    Aug 2009
    #4558
    i'll first try chicks suggestion, if not you might need a glass polishing compound, don't use rubbing compound it can cause visual problems
    Aug 2009
    #4559
    Night Hawk Black
    hirap i-detail nito
    Hehe thats a real challenge but when you see the fruits of your labor, its all gonna pay off when you look at it and say "damn that looks great!"
    #4560
    madkatz & chiks:
    oo nga eh. Panis yung Satellite silver dito pag na-detail ko na.. hehe can't wait
