Results 4,901 to 4,910 of 5910
- Aug 2009
- 1,553
June 20th, 2010 03:36 PM #4901105 = is a lot more aggressive than the m84 you guys used just a heads up, its actually stronger than diamond cut i think
205 = could be a replacement of speed glaze and at times m83 DACP
my suggestions would be either go for 105 and 205
or go for m84 and m83
but i would suggest the 105 and 205 since the correct a lot faster
the m66 is actually just a cleaner wax that can be both machine and hand applied
BTW we're on the process of testing optimum polishes and compounds and so far they seem to be a little better than megs since they have a really longer working time which is safer for beginners so you might also want to check on those, Menzerna also offers very good polishes so you also might want to check those out, since the menzerna roughly has about the same price as the 205 but menzerna definitely finishes better.
June 20th, 2010 03:39 PM #4902
*doc, thanks sir!
*beeco, tama si sir mj09...crystal black pearl cia.
Ganda talaga ng Nano...parang wet paint na malagkit...hehehe.
June 20th, 2010 03:42 PM #4903
- Aug 2009
- 1,553
June 20th, 2010 03:43 PM #4904As for the ONR, its normal to see ONR turn clear with tap water and still be blue with distilled because based on how the CEO explained it to me was that ONR encapsulated the dirt, so if you use tap water it can still function properly but chances are ONR has already encapsulated the impurities in the water and setting them to the bottom of the mixture.
Yup i've tried it already, hmmm maybe its because of the shape of the windshield, hmmm maybe you could bring it over one of these days to my BF he has also used diamondites products before.
- Aug 2009
- 1,553
June 20th, 2010 03:44 PM #4905ScratchX is a lot more aggressive than SwirlX, SwirlX as the name stats is mainly used for swirls but it can also remove light watermarks but for heavier defects you might want to look at scratchX or ultimate compound just be sure to work these products starting from the least aggressive method.
- Aug 2009
- 1,553
- Aug 2009
- 1,553
- Aug 2009
- 1,553
June 20th, 2010 03:49 PM #4908
- Aug 2009
- 1,553
June 20th, 2010 03:51 PM #4909
- Aug 2009
- 1,553
and its right above an electric motor....
BYD Philippines
