Results 3,471 to 3,480 of 5910
- Aug 2009
- 1,553
March 3rd, 2010 11:40 PM #3471*locoroco777: Up and Up for all the replies above, all are very informative and very precise.
Well, just my 2 cents, for me SwirlX and Megs 82 Swirl Free Polish both fall onto two different categories in terms of polish categories.
I classify them into
Very Aggressive Polish - Megs 105/Megs Ultimate Compound
Aggressive Polish - Megs 84
Medium Polish - Megs 83
Light Polish - Megs 82
Finishing Polish - Megs 80/82
For me SwirlX could already be considered a medium polish by hand and even an aggressive polish via PC, its even more aggressive than Megs 83 Dual Action Cleaner Polish which is my standard moderate to light swirl remover using a PC or rotary, i guess this is because of its SMAT technology. You could put SwirlX between aggressive and medium because it can be used two ways, via hand or via PC, in using it via hand if you work it using light pressure it can already give you the results of Megs 86 via PC and with hard pressure you could have the same level of cut as Megs 84 with a rotary, with using it with a PC it gives a more uniform cut, its pretty much like Megs 86 with a rotary. But then i totally agree with jon, again there are a lot of factors to consider and what i wrote down is something that might help you gauge the cut.
If you would look back a few pages, there are pictures of a revo that i buffed using rotary and medium pressure, the polishes i used there are Megs 85, 84, and 83. Then again i polished a Ceramiclear clearcoat which is really tough. Normally the SOP in Megs Simex for serious defect removal is Megs 84 and then followed by Megs 83, but that is for serious defects already. The reason why SwirlX has that much cut is because it is targeted to be sold to the average consumer which does not have a PC and does not know that to properly achieve the best results you would need to work the product onto the paint using moderate pressure through an extended period of time, most people will just apply SwirlX like a wax which means shorter period of time and less pressure. In short SwirlX is made aggressive to still be able to deliver nice results when placed on unexperienced hands, of course its a different scenario when placed on the hands of more experienced people and simply by knowing that you need to work the product using moderate pressure but enough to be able to glide the applicator on the paint and then work the product for about 3 to 5 minutes per large panel, that already puts you above the average consumer in achieving better results. Its like all Megs OTC products that have SMAT are designed to produce nice results through a product that makes some things a lot more simpler.
Megs 82 for me is already considered a finishing polishes 2 categories down, finishing polishes doesn't have any significant cut, it can only remove very light swirls, the kind you could barely see, its called Swirl Free Polish because its a polish in the sense that in adds more gloss to the paint by smoothing out your paint further, but doesn't have that much cut to even leave swirls behind because the abrasives are so small, where in using Megs 84 and Megs 83 its sometimes common to still see buffer swirls caused by the larger abrasives. Megs 82 for me would be ineffective in removing and significant number of swirls but i have had great results using both Megs 82 and Megs 80 in terms of burnishing the paint to a high gloss using a polisher. So guess to shorten things up Megs 82 for me is used for further refining the paint to create a better gloss.
The good thing with SMAT abrasives that i kind of like is that even if its aggressive you still end up with a high gloss, so with using SwirlX chances are once worked properly you would end up with less swirls and a high gloss but that also doesn't mean it cuts less.
Posting pictures would be a great idea to determine if the swirls are moderate or light, i would suggest you use SwirlX for moderate swirls already, it would be a waste if you use SwirlX on light swirls, sure you might remove the swirls but you might also remove more clearcoat than necessary, thus why they all recommended using he least aggressive method. Thats why we would like to suggest if you are using SwirlX, would be to start with very light pressure, remove the product then check if the correction was made, if not work it a little harder and repeat the process until you achieve the desired results.
March 3rd, 2010 11:48 PM #3472
March 4th, 2010 12:27 AM #3473
Ang heavy na ng swirls ko sa trunk. I just don't know yet if it's still swirls or light scratches na. I will try to post pics whenever I have free time so that everybody here can diagnose my problem much better
March 4th, 2010 02:21 AM #3474
Thanks again katz!
that's by far the most valuable 2 cents I've read...
I'll post the pics when my brother comes home with his SLR cam so I can take clearer pics for your evaluation.....TIA
March 4th, 2010 04:42 PM #3475
Kaya pa kaya ma tanggal ng PDR to? Hit n Run sa parking lot. Natanggal ko na yung scratches at paint transfer dent na lang.
March 4th, 2010 09:22 PM #3477
OH *%&%^*$*! :shocked2: grabe bagong bago pa na hit and run na.
sana mabangga ng matindi yung dumale dyan.
sa tingin ko kaya naman ng PDR yan kaso talagang mahirap kasi medyo pa curve yung tinamaang part. nagpa PDR na ako dati sa Trooper, yung part na inayos parang may konting kulubot. pero hindi masyado halata kasi light colored. ewan ko lang sa Silky Bronze
March 4th, 2010 09:31 PM #3478
- Aug 2009
- 1,553
- Aug 2009
- 1,553
Hopefully the system is fool proof to detect edited pictures with altered dates/cover page from the...
transfer of ownership / registration cost
