Quote Originally Posted by ess View Post
Ouchhhh!!!!
That hurts! 2 panels pa man din!
Sarap balutin yung bicycle sa liig nung nakabunggo sa yo. Grrr.
Anyway, since you've mentioned that you can feel the scratch with your fingernails, then it means that it's already too deep.
You may want to try polishing the area with a good scratch remover (mom's or meguiars). That ought to clean it up enough to be less noticeable. (Unfortunately...no matter how you make it invisible to others, it will still be very visible to you...)
If you feel up to the task, you may also want to try some DIY repairs. Check out the guide on how to do DIY touchups at: www.bettercarcare.com. There's an article there on how to repair paint damage, including deep scratches via DIY touchups. It's quite laborious...
thanks po sa info, il try to read the site, thanks po ulit
correctin po pala it did not catch my nails
