Results 591 to 600 of 5910
June 20th, 2005 11:52 PM #592
tipong Polishing Pads lang.. something like Megs Yellow Pad or anything at this level.
wool pads and severe cutting pads hindi advisable. but these give excellent results on a direct-drive motor (Rotary).
in a nutshell, Rotaries can use some Pads which ROP can't.
June 21st, 2005 01:36 AM #593
Dehadista: Thanks for the advise. Wokidoki. Will stick to the regular polisher pads. In this regards, is the megs yellow polisher pad any different from the 3m black waffle polisher pad? (I think both can be used for polishing and application but not for compounding).
Also, would these polisher/applicators ok to use with a medium abrasive/cleaner such as DACP?
ILD: Yup! Hahanap pa nga ako. Sa ace southmall ko pa nakita, 2 last. Really old stock. Is it really a little smaller than the rubber backing plate of the kp600? I need to search other ace shops soon! Baka may tira pa.
What I really like with the 3m pads is the price! I can buy almost three 3Ms (if only they were available) for the price of 1 Megs. Hehehe.
June 21st, 2005 08:21 AM #594
Originally Posted by patopig
1) well, both pads are polishing pads...
2) definitely pwede DACP. work it in.
ganito: for Cutting, Leveling & Compounding, armed with the right CUTTING PAD, a Rotary can do these superbly. for a ROP (variable speed pa dapat), well... it's gonna take you a long time.
depending on your skill level, this can do some serious hazing / damage to your paint.
June 21st, 2005 01:30 PM #596
Wahehehe. Scary. I guess I'll limit myself to the mild abrasives like speed glaze or 3m machine glaze for my car. I'll just use the DACP on really old vehicles (just for learning purposes I guess) and as a plastic polish.
BTW, I did try that! I used the 3m Compound with a polishing bonnet, then DACP with freebie foam applicator then 3m machine glaze on the badly scratched rear light plastic of my Dad's old GSR, it really works! Funny thing is the left rear lights look new now and the right rear lights look old. Hehehe. Will fix that tomorrow.
June 22nd, 2005 01:04 AM #597
had my ride quoted sa bigberts kanina..1.9K for the exterior detailing and another 800php for the engine detail...hayy..mahal..hehehe
June 23rd, 2005 12:25 AM #600
zechs: Not sure, you'd have to ask vince about it. AFAIK they paint protection system, maybe you can avail that package.
I would lean more towards technological solutions instead of deputized traffic wardens, whenever...
SC (temporarily) stops NCAP
