Results 491 to 500 of 5910
June 12th, 2005 10:57 PM #491
ILD: Now that's good. excellent work! no swirls... ansarap tingnan pag walang swirls!
June 12th, 2005 11:00 PM #492
patopig: One time before I knew better, i used a rubbing compund with a rotary to get some scratches. and with a wool pad pa. BAD MOVE. ended up taking away too much clear.
June 12th, 2005 11:09 PM #493
Originally Posted by zechs
June 12th, 2005 11:10 PM #494
dehadista: Does simex carry 6" pads? the waffle pads am using is only 5". What do you pads do you suggest to use with a paint cleaner and wax?
June 12th, 2005 11:19 PM #495
yup meron Megs 6" pads ang simex. for ROP use, I suggest using Polishing (cleaning) and Finishing (Pure Wax, sealants) Pads. A MF Bonnet wrapped in a Polishing Pad would be ideal for wax removal.
Ang mabenta sa Simex na Pad ay yung Yellow Polishing Pads ng Megs. versatile kasi. pwede for polishing and for wax application.
Personally, I reserve the Cutting Pads for the Rotary.
June 12th, 2005 11:29 PM #496
Alright! thanks again dehadista. Am definitely goin to simex and getting 'em pads
O ayan patopig, you can visit simex for your pads.
June 13th, 2005 12:08 AM #499
matagal naman magagamit ang foam pads. its a good investment.
BTW, aabot na 'to sa 500 posts ah...
OT: ILD, since you started this thread, you should make the next post hehehe.
June 13th, 2005 12:22 AM #500
I didn't expect this thread to go on this long, dami din palang detailers dito. Thanks sa mga inputs niyo.
Edit:
Dehadista: Any idea how much the 6" pads cost? price range? Thanks.Last edited by ILuvDetailing; June 13th, 2005 at 01:02 AM.
Imo at that price it becomes a very tempting buy even with its' flaws.
2021 Nissan Leaf
