Results 171 to 180 of 5910
May 17th, 2005 11:44 AM #171
Blackmagic: Where can I buy the Moms Claybar (only) without the cleaner wax and QD?
May 17th, 2005 11:48 AM #172
Blackmagic: Great tip sir! Thanks! Excited na ako subukan sa car ko! Ako pala yung tumawag and nagdeposit kanina! Thanks uli!
May 17th, 2005 11:57 AM #173
ganda talaga ng Mom's claybar! matigas kasi yung sa Soft99 hehehe. nga pala, don't ever drop the claybar. ang bilis maka-pick-up ng dirt.. BTW, soapy water (car shampoo + water) can act as a lubricant.. some dilute their QD's for this purpose too. (1:1)
ILD: I think you can work something out sa Autoplus regarding that..
May 17th, 2005 01:26 PM #176
yup.. it safely removes contaminants. tapos you knead the bar again to get a fresh piece. you can re-use it again this way again and again. make sure to use a lubricant when using clay.
you should clay after washing your car.
May 17th, 2005 03:43 PM #177
Hmm.. So the process would be like
1) Wash and dry
2) Clay
3) Polish
4) Wax
right? BTW If use soap and water as lubricant for the clay, I guess that would mean I would need to rinse the soapy water off right? Or can I just wipe it off (since I think that's the way to do it with clay + QD)?
May 17th, 2005 03:48 PM #178
Originally Posted by patopig
May 17th, 2005 04:48 PM #180
so ang steps dapat is,
1. wash and dry
2. clay and repeat step no. 1
3. polish
4. wax
where do the cleaner wax comes in? right before no. 3?
someones are (at last!) loudly asking, "why did they turn off the countdown timers?"
SC (temporarily) stops NCAP
