Page 281 of 296 FirstFirst ... 181231271277278279280281282283284285291 ... LastLast
Results 5,601 to 5,620 of 5910
    Feb 2009
    #5601
    For me aksaya lang talaga ang jelly blade. Panget na pag konti nalang ang tubig. Parang arte nalang. Learn how to do water sheeting guys! After nyo gawin yun almost tuyo na yung car konti nalang ang tubig. Spot drying naman using your drying towel sa mga natira and curves then tapos na.
    Be practical guys hindi dahil mahal eh effective na. There are other ways to do it and not always "by the book" style.
    May 2009
    #5602
    sir.. nung nagpunta ako sa Autobisyo.. may nakita akong grit guard na kulay red. you may want to inquire kay Jerome.
    Quote Originally Posted by jmpet626 View Post
    So far wala pa nga ko nakikita seller gusto ko din bumili. Pwede ata siya sa mga 5 gallon buckets yung ginagamit na lalagyan ng paints. Yung mga bucket na normal parang hindi kakasya eh.
    Jul 2006
    #5603
    Quote Originally Posted by mau2485 View Post
    +1 kay Mau. Proper sheeting lang then Microtex Elite. Swabe na !!!
    Aug 2009
    #5604
    Quote Originally Posted by boklogs14 View Post
    so ok lang pala mag pa machine wax every month...akala ko po parang mga 4 months bago ako pwede mag pa buff..may nagsabi kasi sa akin na pag lagi daw ginagawa yun parang mawawala daw yung top coat.kasi hindi po ba after mag buff mainit init pa po yung paint..kaya ganon po pagkakainitindi ko regarding sa pag buff..thanks po.
    if it is always buffed to the point where it generates too much heat its already painful to touch then thats really bad for the paint and you shouldn't even do it at all, for the really skilled detailers they don't really get the paint hot, just a little warm and this is talking about compounding and polishing, if the place you're going to makes the paint really how when its just a machine wax procedure then there's something wrong with what they're doing if its a little warm then its ok. Machine wax doesn't really contain any abrasive particles so once its used properly it should not be able to reduce any significant level of clearcoat but if it gets too hot then again there's something wrong there.
    Aug 2009
    #5605
    Quote Originally Posted by Reepicheep View Post
    So what can I at least do every month to remove some swirls? My new monty is already getting some.
    Hehehe well if you're planning on removing them then you'll need a polish for that, and that means reducing clear coat, so why not just fill them? there's Microtex Nano Glos, NXT, and step 2 for that
    May 2008
    #5606
    Quote Originally Posted by madkatz View Post
    Well that's what I'm doing right now, spot step 2. Ganun na nga lang siguro. Btw, thanks for your advice, will opt instead for Microtex elite. Kay Edwin ko na rin kukunin.
    Mar 2005
    #5607
    Got it for 1.3k if I remember it correctly.
    Yes sir plush lang with aid of my blower. Will buy a jelly blade soon para mas madali.
    San nyo nabili sir mura na yan sa 1.3k sakin JCk din 1.5k bili ko. Meron siyang parang bag na itim na attatchment para saan kaya yun?
    Mar 2005
    #5608
    Quote Originally Posted by beeco View Post
    nag inquire ako 850 each...
    Aug 2009
    #5609
    Quote Originally Posted by Big_daddy View Post
    Hi all,
    Will Klasse AIO be able to replace a true polisher for nothing more than the most light swirl marks/bird dropping etches and water marks?
    I'm seriously considering using a polish to remove light scratches, but apprehensive about the results since I don't have access to a RO machine polisher and intend to just use hand polishing.
    TIA
    if they're really really light then yes it can help in removing some stains and visually eliminating scratches
    Aug 2009
    #5610
    Quote Originally Posted by weszt View Post
    *jmpet626
    sige try ko sila tawagan tomorrow kung nagbenta sila. kakatamad kasi to my transformer pa..ehe
    *madkatz.
    meaning yung AG SRP sealant na din yun? hindi ko na pwede lagyan M21 pag nag lagay ako ng AG SRP... balak ko kasi pag ka polish ko ng AG SRP , lagyan ko ng M21 tapos yung nxt gen tech wax 2.0 na paste. pero sympre caly muna..
    cge yung bosch na lang muna bibilhin ko pang wax at pang polish ko yun...
    eto ba ung sinasabi mong WP1300
    http://www.blackanddecker.com/produc...view=4#details
    ibang model n yan 11amps parang malakas na talaga yan...hehe
    pag nagamit naman ng rotary diba dapat light pressure tapos wag papatagalin sa isang place. yun rpm lang hindi ko alam kung gaano kabilis
    It sort of functions as a cleaner sealant pretty much like klasse AIO but of course AG SRP finishes a lot better, and yes you can apply M21 after, the name of AG SRP is very confusing in the sense that its not really a polish
    Aug 2009
    #5611
    Ahh see theres an air intake hole and theres an air output hole in the blower, if you use it as a blower you put the pointed rubber nose on the output, you can also replace the rubber nose with the black bag in the air output hole and then put the rubber nose in the air intake hole to turn it into a spot vacuum cleaner hehe
    Aug 2009
    #5612
    Quote Originally Posted by x_jason_x View Post
    Jmpet626,
    May mabibilihan ba ng grit guard dito sa Manila? Dati kasi i'm planning to buy from states kaso lang i'm not sure naman kung it will fit my bucket.
    Actually we used to sell Grit guards at 750 pesos but we didn't get any demands so we stopped shipping them i don't know if we still have some, and we also find it too expensive to ship because of their size, shipping 4 grit guards is like shipping 2 gallons of polish already so the cost is really higher when it comes to grit guards so we just opted to ship fast moving items
    Mar 2005
    #5613
    *madkatz
    How about meguiars D151 Paint Reconditionong Creme? Same din ba sila ng AG SRP? Read somewhere na almost same agressiveness ng swirl X and also protection ng NXT wax..
    Aug 2009
    #5614
    *madkatz
    Ahh D151 is a lot like Megs 66, for me the difference lies only with the abrasives used, 66 uses diminishing and d151 uses SMAT, its not the same as AG SRP the closest i can compared to AG SRP is Klasse AIO its pretty much like a sealant with milder than KAIO cleaning abilities although it uses mechanical abrasives as its cleaners so yes it can smooth out some swirls but not on the same level of correction as 66 and d151, AG SRP is actually considered by most as a sealant already but in the truest sense its a cleaner sealant like KAIO, FK Ultra Wipe, OPT Poli-seal and werkstat prime
    Mar 2005
    #5615
    Found this article about SMAT products agressiveness
    From
    http://www.autogeekonline.net/forum/...prise-you.html
    Mas aggressive pa pala ang d151 kesa swirl X
    Super Micro Abrasive Technology = SMAT
    From left to right, the most aggressive to the least aggressive SMAT products
    May 2008
    #5616
    I need help. I usually place these non-slip mats on our cars. Unfortunately for my Montero, maybe due to the heat on that day, the mat sticked on the dash and left some marks. I brushed it with 10:1 APC and it removed some marks but not all.
    Jun 2010
    #5617
    sorry double post
    Jun 2010
    #5618
    From
    Nice, very helpful visual aid.
    Whew kakatakot din gumamit ng masyadong aggressive, unless kailangan talaga. Kaya oks na siguro ang swirlX kung pantanggal lang ng light scratches and watermarks
    Aug 2009
    #5619
    oo nga confusinfg yung name nya super resin polish... hmmmm
    halos wala pa ako sa kalahati na ng buong thread na to.. hirap tapusin hindi ko matapos pero tatapusin ko to....=)
    matesting nga yung Deep crystal paint cleaner ng megs bago ako mag polish. 369 lang dito eh.
    *madkatz
    meaning yung Nxt gen tech wax 2.0 nakakatanggal ng swirl? meaning nafifill nya ung mga swirl? tapos after several car wash lalabas ulit sya?
    per advantage nito hindi ka nag sacrifice ng clear mo? tama ba ako? hmmmm
    dami kasing swirl ng sa akin nung pumwesto ako dati sa lamp post ng meralco.. kitang kita parang pwede ng lumambitin si spider man...hehe
    Aug 2009
    #5620
    From
    *jmpet626
    wow nice nice research matagal ko na hinahanap yan... buti swirlx muna binili ko. less aggressive sya.. wow yung UC at scratch X halos nasa dulo na. bakit nawala dito yung rubbing compound?
