Quote Originally Posted by madkatz View Post
It depends on how you define machine buff
if its
machine wax = meaning application of cleaner wax and then removed via machine using a pad then you can have this done every month
2 step = meaning using a polish and then machine wax, then you can have this done every time you get a lot of swirls on your car
3 step = meaning using rubbing compound, polish and machine wax then i would suggest you only avail of this service only when desperately necessary since this really does remove a considerable amount of clear coat
Then again, bottom line, it still depends on the level of the detailers skill, my Bf recently saw a Revo that was really shiny and glossy and it was 3 stepped 5 times and it still has some orange peel and i've seen a car 3 stepped only thrice and it already striked thru the primer
So what can I at least do every month to remove some swirls? My new monty is already getting some.
