Page 1 of 2 12 LastLast
Results 1 to 20 of 5910
    mga boss pwede po ba magtanong. gano katagal ang interval pag kunwari nag pa machine buff lang ako last month..kelan po ako pwede mag pa buff ulit??ung .. yung jebs kasi ng ibon ang hirap na matangal..iniisip ko baka ok nmn ipa buff na lang siya.. salamat..
    Aug 2009
    Quote Originally Posted by boklogs14 View Post
    It depends on how you define machine buff
    if its
    machine wax = meaning application of cleaner wax and then removed via machine using a pad then you can have this done every month
    2 step = meaning using a polish and then machine wax, then you can have this done every time you get a lot of swirls on your car
    3 step = meaning using rubbing compound, polish and machine wax then i would suggest you only avail of this service only when desperately necessary since this really does remove a considerable amount of clear coat
    Then again, bottom line, it still depends on the level of the detailers skill, my Bf recently saw a Revo that was really shiny and glossy and it was 3 stepped 5 times and it still has some orange peel and i've seen a car 3 stepped only thrice and it already striked thru the primer
    so ok lang pala mag pa machine wax every month...akala ko po parang mga 4 months bago ako pwede mag pa buff..may nagsabi kasi sa akin na pag lagi daw ginagawa yun parang mawawala daw yung top coat.kasi hindi po ba after mag buff mainit init pa po yung paint..kaya ganon po pagkakainitindi ko regarding sa pag buff..thanks po.
    Aug 2009
    if it is always buffed to the point where it generates too much heat its already painful to touch then thats really bad for the paint and you shouldn't even do it at all, for the really skilled detailers they don't really get the paint hot, just a little warm and this is talking about compounding and polishing, if the place you're going to makes the paint really how when its just a machine wax procedure then there's something wrong with what they're doing if its a little warm then its ok. Machine wax doesn't really contain any abrasive particles so once its used properly it should not be able to reduce any significant level of clearcoat but if it gets too hot then again there's something wrong there.
    May 2008
    Quote Originally Posted by madkatz View Post
    if its
    So what can I at least do every month to remove some swirls? My new monty is already getting some.
    Mar 2005
    Quote Originally Posted by Reepicheep View Post
    Sir proper washing technique using MF washmitts, 2 bucket method and MF or waffle weave drying towel para ma minimize ang cause ng swirl marks. Everytime na nag reremove ka ng swirl marks little by little nababawasan ang clear coat ng paint.
    Kung hand application ok ang Megs Swirl X and maintain with Wax.
    Aug 2009
    Quote Originally Posted by jmpet626 View Post
    *jmpet626
    diba pwde din gumamit ng ROP sa megs swir x?
    Mar 2005
    Quote Originally Posted by weszt View Post
    *jmpet626
    Yes sir pwede by hand and ROP. Maganda din reviews ng swirl X kahit hand application.
    May 2008
    Yep sir I'm even doing a 3 bucket method, one bucket for top panels and other one for bottom/wheels. Using 4 Microtex plush + blower to dry the whole thing.
    Jul 2006
    Bro what kind of blower are you using? And how much? Naghahanap rin kasi ako ng blower.
    Mar 2005
    Wow tyaga nyo sir plush MF towel lang sa montero? Ako hirap na hirap mag car wash ng montero ang taas kasi masyado. Try using washmitt and 2 bucket. 1 bucket for rinsing the washmitt when it gets soiled and the other one filled with shampoo. Kung OC talaga you can also use grit guard on both buckets para hindi mag recirculate yung dumi sa bucket.
    Jul 2006
    Jmpet626,
    May mabibilihan ba ng grit guard dito sa Manila? Dati kasi i'm planning to buy from states kaso lang i'm not sure naman kung it will fit my bucket.
    May 2008
    Quote Originally Posted by x_jason_x View Post
    Got it for 1.3k if I remember it correctly.
    Yes sir plush lang with aid of my blower. Will buy a jelly blade soon para mas madali.
    Aug 2009
    Hehehe well if you're planning on removing them then you'll need a polish for that, and that means reducing clear coat, so why not just fill them? there's Microtex Nano Glos, NXT, and step 2 for that
    May 2008
    Well that's what I'm doing right now, spot step 2. Ganun na nga lang siguro. Btw, thanks for your advice, will opt instead for Microtex elite. Kay Edwin ko na rin kukunin.
    Jul 2006
    Just got home. This afternoon umambon sa office. Then kanina pauwi nko nakita ko roof and trunk ko.
    476s + mothers step 3 applied yesterday morning. Dko mapigilan kanina kaya kinuhanan ko ng pic.
    Nice beading sir matt! Parang di gumalaw yung tubig ah haha.
    Jul 2006
    migz, oo nga ano. hehehe ambon lng naman kasi kaya cguro ganyan
    Jun 2010
    Quote Originally Posted by dotnetmatt View Post
    476s + mothers step 3 applied yesterday morning. Dko mapigilan kanina kaya kinuhanan ko ng pic sa cell ko.
    WOW literal na beads thumbs up talaga 476!
    Jul 2006
    Quote Originally Posted by kafph2000 View Post
    Kafph, tama boss
