Page 273 of 296 FirstFirst ... 173223263269270271272273274275276277283 ... LastLast
Results 5,441 to 5,460 of 5910
    Jun 2010
    #5441
    Quote Originally Posted by bombitmd View Post
    Question pala regarding the ONR: Anong difference between the waterless wash and the no rinse wash?
    From what I understand, yung waterless wash, yan yung when you dip your washmit in the solution, then wipe and dry per panel, tama nga ba? So, how do you use the no rinse wash?
    Waterless Wash:
    - Dust the car
    - Spray the waterless wash on one panel..be liberal with the spray, esp if the car is really dirty.
    - Use one MF to remove dirt
    - Use another to dry
    No Rinse
    - Dilute a small amt of ONR to a bucket of water (1:256 as per madkatz)
    - Dip your washmit in the solution, and wipe the car with it
    - Use wipe with one MF to remove dirt
    - Wipe with another to dry
    Difference.... ung no rinse may bucket of water ka... sa waterless, pa-spray-spray lang. I also read in some threads another no rinse technique using 2 buckets...
    - Fill one bucket with distilled water
    - Dilute a small amt of ONR to another bucket of distilled water
    - Dip your washmit in the ONR solution and wipe the car with it
    - Dip the washmit in water to let lose the dirt, remove excess water, and repeat the last 3 steps.
    Mga pafs... feel free to crrect po...
    and alos? which method do you prefer more? No rinse or waterless?
    #5442
    *jmpet / rico - thanks! Sige, try ko mamaya. Na ambunan nanaman... haaayyyy
    Aug 2009
    #5443
    Madkatz & Chikselog:
    Hmmm i would recommend he remove the whole thing again using Glass Scrub and then apply Rain Clear again, the streaking should be easy to remove i dunno why it streaked in his case, usually i just use my bare hands to spread the rain clear and very little is needed like only 3 to 4 green pea sizes for the whole wind shield, you just really have to massage it to spread it very thin and then i remove it with a MF cloth or newspaper
    Aug 2009
    #5444
    Rinseless is when you use 2 gallons of water with 1 oz of no rinse and wash your car, and you dip your washmitt on the solution and wring the washmitt again in the solution, the waterless wash is when you use it like a QD but instead of misting the surface you liberally cover the whole panel and you use a MF cloth to wipe the dirt off and another to dry it after, once you wipe one panel with a MF cloth you don't use that side again, so you end up using 4 MF cloths for the whole car, 3 for wiping and removing dirt and 1 for drying.
    So yes its pretty much like what Rico said but for the waterless wash you really soak it and let it sit for about a minute.
    #5445
    Quote Originally Posted by madkatz View Post
    +1 dito. Glass Scrub na lang ulit. Ako tissue pang apply ko Rain Clear haha. Tinry ko na kamay pero mas trip ko yung tissue hehe. Medyo dumidikit sa kamay ko, ayaw na mag-spread masyado.
    Mar 2005
    #5446
    Single Stage Paint ata gamit ng toyota. Paint kagad yung natanggal nung nag buff ako
    After M83
    After spin cleaning ng pad with a toothbrush
    NXT 2.0 at 476s
    #5447
    WOW. Just.. Wow. :shocked2:
    Aug 2009
    #5448
    Yup, same here, i am awestruck, and to think that you just recently learned polishing about a month ago, really good job!
    BTW you have to give that pad another spin, try some degreaser, your pad might become stiff if its not thoroughly cleaned
    #5449
    *jmpet626
    parang salamin na yung ride mo...
  10. #5450
    nice detail! btw, what's your machine? bago ah. pads are 6.5-in?
    Jun 2010
    #5451
    tindi nito sir JM!!!! Anu combo mo dito??? M83 lang? --- disregard... NXT pala at 476s... grabe lufet!
    #5452
    wow! super-reflections! Ginamit mo ba yung BnD na binili mo kay sir Ed?
    Mar 2005
    #5453
    *madkatz
    Yup degreaser yung gamit ko after final washing yung nasa pic nilinis ko lang yung pad after moving to a new panel.
    *azzkkr2600
    Yung inorder ko kay sir edwin na Black and decker wp1300k. Yung pads is 6.5 inch na ccs pads. Mas safe para sa newbie kasi hindi mabilis uminiit yung surface ng paint dahil dimpled siya.
    *rico_g
    Yung m83 sa hood lang dahil may watermarks na.
    #5454
    as requested by SG...
    minadali ko na lang ito dahil may lakad pa kami pagkatapos. gamit ko lang ay TW Platinum, uubusin ko na lang bago ako bumili ng NonaGlos at Sliq.
    #5455
    Buti pa yang sayo James ang kintab Tapos yung wheel wells mo sobrang linis pa
    Nakaka guilty ka naman. haha
    ayaw mo talaga ipakita yung mags ah
    #5456
    *SG
    sige, next time picturan ko rin yung mags sa susunod na pag-wax ko.
    malamang TW Platinum pa rin yun, hopefully doon na mauubos yung wax ko para makabili na ng NanoGlos at Sliq.
    #5457
    Quote Originally Posted by james00112233 View Post
    *SG
    I mean ayaw mong makita yung mags para di mabuking na 4WD haha
    Alam mo yung 2010 CR-V ngayon halos wala na pinagka-iba yung 2WD sa 4WD. Hindi na worth bumili ng 4WD kasi mapapagkamalan ka ring 2WD
    #5458
    tama ka dun. napagkamalan ko ngang 4WD yung 7-spoke alloy ng 2010 CRV. OT na tayo... hehehe...
    Apr 2008
    #5459
    Tap water could degrade the abilities of ONR so i really suggest you just get purified or distilled water, distilled water of course is the best to be used, you could contact my BF at +639277227554 for the ONR
    thnx ma'am for the headsup...
    ano po yung OCW and OGE...yung nano sliq may nakikita ako neto sa blade ang ace hardware..
    quick detail ba ito? parang wala kasi ako nakita sa packaging nya kung wax ba siya o QD..
    Oct 2009
    #5460
    Hi,
    Is there a proper way to wash the MF's? Tried washing thru detergent soap then dry. After using for a second time meron siyang parang mga pulbos naiwan I think galing dun sa wax. How do we get rid of this?
    Thanks - BS
