Results 4,551 to 4,560 of 5910
- Aug 2009
- 1,553
June 11th, 2010 02:15 AM #4551
June 11th, 2010 06:43 AM #4552
- Apr 2010
- 85
June 11th, 2010 11:08 AM #4553
June 11th, 2010 12:41 PM #4554
I would suggest Elevo Watermark Remover. It's P280 only and you can find it in your favorite hardware stores. Just be careful in using this and be sure to wear gloves (the package says so) because this is an acid I think, judging from the smell.
*madkatz
Alright! Thanks for the clarification.
June 11th, 2010 12:54 PM #4556
- Aug 2009
- 1,553
June 11th, 2010 01:07 PM #4557That would be a cheap alternative to removing waterspots on the windshield, but thats just for moderate to light, for heavy duty ones you actually need to use a Glass Polishing Compound, and yeah the Elevo uses acid in their kit as with glass polishing compound, actually nearly all water mark removal system incorporates acid to remove water marks its just a matter of how strong the acid is, if you've tried the acid for aluminum brightener the one i think you guys used on the engine detail, you actually use the same acid for Glass Polishing
- Aug 2009
- 1,553
June 11th, 2010 01:09 PM #4558
- Aug 2009
- 1,553
June 11th, 2010 01:11 PM #4559
June 11th, 2010 01:17 PM #4560
madkatz & chiks:
oo nga eh. Panis yung Satellite silver dito pag na-detail ko na.. hehe can't wait
have your compression checked... if Manual yang Montero mo... try mo patulak if ayaw mag start...
