*SG: nice detail on all 3 rides! all that work and painful muscle is well worth those vehicles looks
*chickselog: i wouldn't recommend using elevo water mark remover to those since you're dealing with either paint or plastic for one which is a lot more sensitive, and reason 2 is because most water mark removers are actually strong acids that can eat through water marks so i guess im with you on your hunch with it turning white. For both plastic and paint you could try using some APC and some old toothbrush to scrub it gently to remove whatever white stuff you can remove. As for the wiper i guess thats paint over metal so maybe you could try on some paint cleaners and try in on a small test spot and see if it works, oh yeah maybe you should add more water to your washer reserve to dilute the solution and hopefully make it less stronger. As for the black plastic parts, you could dry cleaning them with APC + MF + Toothbrush and then finish it off with some Moms Naturally Black or Megs Ultimate Trim Detailer. Oh yeah in everything you do always test it on an inconspicuous area first before you apply it to the whole.
Happy new year to everyone!!
