Results 2,911 to 2,920 of 5910
September 11th, 2009 08:44 AM #2911
- Aug 2009
- 1,553
September 15th, 2009 02:30 PM #2912for now it would be by hand, but im saving up for a ROP so i might as well get your take on machine application as well, thanks
September 15th, 2009 08:53 PM #2913
I see.
You could get the Megs UC and the SwirlX if you're going to do some correction.
The glazes you possess have some filling and mild "cleaning" properties, so if the performance of these products are ok with you, then I guess you don't have to find new ones.
If you're after a glaze that still fills but has no "cleaning" properties, then you might want to consider the Danase Wet Glaze.
Hope this helps.
- Jul 2009
- 12
September 16th, 2009 05:36 PM #2914I just got my 2009 FD Taffeta white last 2 july. Yesterday I asked my maid to clean the car and since it has rained much in our area non stop, maduming madumi na talaga. Previously I noticed road grime and asphalt build-up (maliliit na maitim) that has stuck dry to lower portions of the car. Not minding those black specks as I plan to remove them on my own, di ko muna sya inalis. I was shocked to realized that my maid did the initiative of removing those, kaso she used scotch brite and gas. Natural naalis but the scratches and swirls left are significant. Kainis!!! Can these still be buffed out DIY? Hu hu. Hassle kasi kung ipasok ko pa sa shop, gastos na, la pa ako car!
September 16th, 2009 06:19 PM #2915
If the defects are not deep, then yes, they may be corrected through polishing.
Whether or not it should be DIY is another matter. Unless you have successfully done some paint correction on that car, I humbly suggest that you have it checked by a pro detailer.
Hope this helps.
- Jun 2009
- 185
September 16th, 2009 06:41 PM #2916
September 16th, 2009 07:07 PM #2917
- Jun 2009
- 185
September 16th, 2009 07:20 PM #2918hi liv! got our new innova!
its color black and its so shiny when it was released but after 5 days, not only is it a mess, our stubborn cat left scratches when he climbed the hood. damn it cat!
can you recommend a good set of cleaning materials pls. I'm kind of a virgin at this car wash/paint protection thingy heheh..
- Jul 2009
- 12
September 16th, 2009 10:37 PM #2919
Tsikot Member Rank 3
- Mar 2004
- 2,053
September 17th, 2009 09:32 AM #2920Before you do anything to fix those scratches, you should solve your cat problem first. Like it or not, your cat has already designated your innova as its home. Aakyat yan ng aakyat, at mamanchanan at gagasgasin.
If you fix those scratches now, the following day, pwede ka muli magka-scratch because of your cat.
Get a car cover or find another way to dissuade your cat from climbing the car.
Then that's the time you should consider repairing the damage.
Interesting thread—really important to consider the broader impact of the National ID Law beyond...
National ID Law
