Results 2,881 to 2,890 of 5910
June 17th, 2009 05:02 PM #2881
good thing na nakadaan ako dito sa thread na ito, because i'm also having a hard time to fix the fingernail scratches in the door handles (plural kasi lahat sila)
..and I found out the solution here... thanks a lot. :groupwave:
Tsikot Member Rank 3
- Mar 2004
- 2,053
June 18th, 2009 08:15 AM #2883Slightly OT:
Those fingernail scratches under the door handles are a real mystery to me. Whenever I have lady passengers, I always politely tell them to open the door carefully and never allow their fingernails to touch the car. Pero meron pa rin gasgas! (Albeit.. konti lang compared sa ibang cars.)
The alarming thing is -- even the driver side door (my door) has scratches under the door handle. Halos wala na nga akong kuko dahil nail biter ako. And I'm the only one who drives my car. :dunno:
June 18th, 2009 05:26 PM #2884
- Mar 2007
- 63
July 12th, 2009 07:34 PM #2885Guys,
Ok lang ba kung punas punas lang yung car? i mean, gamit mo lang is a pail full of water and yun lang gagamitin mo panglinis? nagttipid kasi ako sa carwash. sayang sa pera eh. 60pesos din yun.
tsaka yan din ang gawain ni erpats sa bnew yaris nya... is it good to the paint in the long run?
If not, then what shoud be done kaya in an economical way?
- Mar 2004
- 2,053
July 13th, 2009 11:27 AM #2886Depends on the situation. If your car only has a light cover of dust, then pwede yung bucket + trapo.
However, kung may nagtutong na road film + dirt (usually ganito mangyayari sa side panels mo after running on wet roads), hindi na pwede yung bucket + trapo. When this happens, you should use a bucket + wash mitt + car shampoo. If you use a bucket + trapo on this one, magkaka swirls ka.
- Jun 2009
- 160
July 13th, 2009 11:46 AM #2887
July 13th, 2009 11:52 AM #2888
there's no substitute for a good car wash. just do it yourself para makatipid ka. pero wag mo tipirin sa procedures at sa materials.
July 13th, 2009 12:08 PM #2889
anong pwedeng pang tanggal sa grasa sa pintura? without compromising the paint
- Mar 2004
- 2,053
July 13th, 2009 02:43 PM #2890A wash mitt is a big glove with either wool or cotton/chenille nap. The purpose of the wash mitt is to be able to hold more water and car shampoo solution and allow you to was a larger surface area. The nap will also capture and trap dirt and prevent it from scrubbing on the paint surface of your car.
Swirls are very shallow BUT numerous scratches on your car's paint. If you park your car under the sun or if you aim a flashlight to your car, and you start seeing cobweb like patterns, swirls yon. Improper washing techniques often cause swirl marks. (Having your car washed by those pesky mall carwash boys is a sure fire way of getting swirlmarks. :D )
Try using your car shampoo first... maybe even try using it undiluted (pure) on the grease spots. If it works, make sure to immediately follow up with a full coat of car wax.
Specs, prices, features: Everything you need to know about the all-new Hyundai Kona | TopGear PH...
Hyundai Kona (2nd Gen)
