Results 1 to 10 of 11
- Jan 2005
- 19
October 27th, 2006 02:48 PM #1Hi guys,
I found 2 small drops of concrete on the roof of my car. We couldn't remove them - tried kerosene, clay bars, etc - no effect.
Any suggestions?
Thanks in advance for the help.
October 27th, 2006 02:59 PM #2
vinegar, kung ayaw pa rin.. small amounts of muriatic acid. wash immediately with soap and water. wax.
October 27th, 2006 03:02 PM #3
as far as i know, hindi masyadong kumakapit ang cement sa kotse. na experience ko na yan. gumamit ako ng hose then napulbos na yung cement.
gano ba karaming cement yan? baka isang bag yan?
October 27th, 2006 03:08 PM #4
Kung parang Hershey's Kisses na chunk, hindi iyan kakapit, you can pry it off after a while.
- Jan 2005
- 19
October 27th, 2006 03:10 PM #5thanks for the reply! I'll try the vinegar/muriatic acid thing later - sana di mabakbak paint ko.
there are just 2 small drops - problema natuyo na sila when i noticed, so ayaw nang matanggal.
nag park kasi ako sa serendra, siguro dahil under construction pa siya kaya natuluuan ng concrete.
keep the suggestions coming. thanks in advance.
October 27th, 2006 03:12 PM #6
Get a needle or pin, then try to "break" the hardened concrete.
Worked for me.
October 27th, 2006 05:32 PM #7
yup, ala mini jackhammer hehe... pour some vinegar on it while you're doing it as well.
- Jan 2005
- 19
high idle RPM at engine start
