Results 1 to 11 of 11
    Hi guys,
    I found 2 small drops of concrete on the roof of my car. We couldn't remove them - tried kerosene, clay bars, etc - no effect.
    Any suggestions?
    Thanks in advance for the help.
    Aug 2005
    vinegar, kung ayaw pa rin.. small amounts of muriatic acid. wash immediately with soap and water. wax.
    Oct 2003
    as far as i know, hindi masyadong kumakapit ang cement sa kotse. na experience ko na yan. gumamit ako ng hose then napulbos na yung cement.
    gano ba karaming cement yan? baka isang bag yan?
    Kung parang Hershey's Kisses na chunk, hindi iyan kakapit, you can pry it off after a while.
    thanks for the reply! I'll try the vinegar/muriatic acid thing later - sana di mabakbak paint ko.
    there are just 2 small drops - problema natuyo na sila when i noticed, so ayaw nang matanggal.
    nag park kasi ako sa serendra, siguro dahil under construction pa siya kaya natuluuan ng concrete.
    keep the suggestions coming. thanks in advance.
    Sep 2006
    Get a needle or pin, then try to "break" the hardened concrete.
    Worked for me.
    yup, ala mini jackhammer hehe... pour some vinegar on it while you're doing it as well.
    it worked! problem solved - thanks guys!
    Jun 2005
    Quote Originally Posted by xpg View Post
    Congratulations.
    Sep 2006
    Ano sa mga sinabi namin ang nagwork?
concrete on roof
